BeerySquash
- Joined
- Jan 12, 2022
- Messages
- 85
I picked up this Galant GSX in January just after new years, it had been sitting in a field for a couple years and all I knew about it was it had rod knock, flat tires, and some rodent activity in it. The tires were cracked badly, so I put in just enough air to get it rolling without blowing out the sidewalls, which made it fun to unload at home with about 18psi in an icy driveway and 15 degrees out.
My initial plan was to drop the pan and inspect the cause of rod knock, then if the damage wasn't too severe, I would polish the rod journals and put in some new bearings. After that I wanted to slowly piece together am OEM(ish) turbo kit and make a pretty standard street car out of it. The more I dug into the car, the more that plan went off the rails. I checked the history on it also and I was the 12th owner, the car car obviously had a very hard life.
I began working on it the day after I got it home and quickly realized the extent of the rodent damage on the interior. It being near 0 degrees definitely suppressed the smell so I didn't think it was too bad. Mice had found their way into every single area of the car, and into areas I didn't even know were accessible. Under all of the pounds of nests, droppings, and seed casings was urine sludge soaked into every part of the car and working it's way under the sound deadening.
