fuel setup
Redwood
Moses Lake, Wa
well im in the process of getting all of my fuel lines ready to go in. but i was wondering if i could get some pictures of how you guys setup your fuel system up. like location that you put the fuel filter in, where you ran the lines.
thanks for the pictures and info
Redwood
Moses Lake, Wa
yes i am. was just trying to see where other had located fuel filter, regulator, and how the lines were ran to and from. was just looking for ideas on stuff.
TomN
North Port, Fl
I ran the lines in pretty much the same location as factory ones and put the filter where the factory one was.
Redwood
Moses Lake, Wa
thats kind of what i was planning on doing TomN just wanted to check around first. thanks for the info
TomN
North Port, Fl
You can keep the stock fuel filter also. It flows great and is good for more hp than most here will make. Just run a line to it from the tank and from it to the rail.
