Fuel Pressure Problem!
Just got done with an engine swap. I removed all of the emission vacuum lines and what not and well... I can't seem to find the fuel pressure regulator solenoid. Was wondering if anyone had a picture of where it's located or would be able to tell me. Thanks
jepherz
KC, Missouri
It's located on the air can stock. However, it doesn't actually do anything with adjusting the fuel pressure besides blocking vacuum and raising the pressure when hot starting the car. All you really need to have is a vacuum line from the intake manifold to the FPR.
To be exact, it is on the REAR of the aircan. The BCS solenoid is on the front of the aircan. The FPR solenoid gets connected via those metal tubes between the block and the firewall. Some people have hotstart issues if they remove it. You just have to feather the throttle for a few seconds.
