FS: Stuff left over from full build sale
alansupra94
Wayne,NJ
Well I have some stuff left over from my build that I decided to sell.
- Set of FP2 camshafts READ I got them from a friend and after taking it to the machine shop, they told me that the lobe had been damaged on the exhaust camshaft. The intake side should be fine if you polish it. I will post up pictures asap. I know that you can fix them if you know someone that is good with cams but I ended up getting some crower 280 camshafts. - $75
- (2) Stock turbo throttle bodies (have to see what sensors they have) - $25 each
- (2) Intake manifold - $25 each
- (1) Set of 6 bolt rods and pistons - $25
- (2) Oil pumps with STRAIGHT cut gears. Look to be in decent shape. - $15
- (1) Water pump - $10
I will post up pictures ASAP.
Thanks,
Alan
973-900-0981
OZRally
Illinois
I'm interested in the oil pump with straight cut gears. Have you measured the clearances to make sure they are still usable and also how does the rest of the housing look?
