mooserage
Cleaning out my garage, will add parts as I can...
Have a lot of parts, prices include paypal fees, but not shipping. Open to reasonable offers and package deals.
Good Guy Thread for Reference: Click
Part 3:
NGK BPR6EIX Iridium Spark Plugs - $10 Click1
CM (Certified Muffler) 3" Cat Delete Pipe (Test Pipe) - $80 (Info: Click) Click1
NOS Grey OEM Wingless 3rd Brake Light - $40 Click1 Click2
Flex-a-lite (FAL) 12" Fan - $20 (Cut-out for BOV clearance) Click1
OMP Universal Co-Driver Aluminum Footrest - $20 New, but assembled for fitting Click1
ETS Intake w/ -10AN BOV Return, K&N Filter, Elbow for 16G Turbo - $110 Click1
New OEM Heater Hose Kit MB527995 - $45 Click1
Part2:
New AMG Replica Grill - $40 Ebay Ad Info (Still in the packaging, went a different route) Click
Part 1:
New Allstar 3" Brake Duct Hose (300*) - $25 Click (I used a little, it didn't work out, there is at least 8' still there, likely more)
New Summit Racing 6AN SS PTFE Hose (15') and hose ends(2x straight, 2x 45*, 2x 90*) - $100 click 1 Click 2
AEM EMS V1, Serial Gauge, IAT, MAP Sensor, Brantz rally trip meter, Harnesses (Not pictured, but included: Serial Cable) - $500 Click (Ran the car with this for nearly 10 years, decided to go to ECMlink)
RC 550s - $70 Click (Worked great for years, probably need a cleaning)
Galant Non-ABS Brake Lines and Proportioning Valve - $40 Click 1 Click 2 Click 3 Click 4 (Bought used, never used myself. Shipping will be expensive, some lines may need slight massaging to get into perfect shape)
AVC-R - $165 Click
Free Pile! (Free, but you pay shipping)
To recycle on 6/13 OEM Brake Reservoir w/ sensor Click1
To recycle on 6/13 OEM BOV Return Hose Click1
To recycle on 6/13 OEM Fan Blade & Motor (Working when pulled) Click1
To recycle on 6/13 OEM Water Pipe & Water Cooled Oil Filter Housing Click1 Click2
Battery Cutoff w/ Removeable Key Click1
100AMP and 150AMP Circuit Breakers Click1
BNIB Russell 626010 120* -8AN Twist-Lok Hose End Click1
To recycle on 6/13 Galant VR-4 ABS proportioning Valve (pulled working about a year ago) Click
To recycle on 6/13 USDM Summit White fuel door Click 1 Click 2
To recycle on 6/13 Galant ABS computer core Click 1 (trunk mounted unit, disabled for the 15 years I owned the car, consider it a core)
To recycle on 6/13 Cut up stock intercooler tubing, believe this was used to adapt a JDM Galant intercooler click
*Recycled* Galant ABS Hydraulic Unit core (disabled for the 15 years I owned the car, consider it a core)
*GONE* OEM Dipstick & Tube Click1
*GONE* Almost New Autometer 52mm (2") Gauge Pod Click1
*GONE*Energy Suspension tie-rod boot Click
*GONE* OEM Summit White Fuel Door and Lock Click1
*GONE*JDM hood vent rain guards Click 1 Click 2
*GONE* Blue Aeroquip FCV0606 6AN 6' Socketless Hose Click
*GONE* Galant throttle body and oil pan gaskets Click
*GONE*Partial Energy Suspension control arm bushings (large bushings only) Click
*GONE* OEM Rear Bumper Marker Lenses Click1
SOLD
*SOLD*NOS OEM Keyless Fuel Lid - $30 (Factory primed, some scratches in primer)Click1 Click2 Click3
*SOLD* New Prothane Poly Motor Mount kit - $65 Click
*SOLD* New Aeroquip 6AN PTFE SS fuel hose (20', Aeroquip FCC0620) w/ used and new steel fittings - $80 Click
*SOLD* STM ARP Stainless Exhaust Manifold Stud Set - $80 Click
*SOLD* New English Racing 2G/Evo 1-3 Phenolic Intake Manifold Gasket and Hardware NLA - $50 Click
*SOLD* Trick flow 6AN Fuel Filter w/ new 40Micron filter - $25 Click
*SOLD* AEM Tru-time Cam gears - $100 Click 1 Click 2 Click 3 Click 4 Click 5 (see photos for light damage on teeth)
*SOLD* New Ingalls FastCam Front Camber Bolts (Pair) - $30 Click
*SOLD*JDM Grey Keyless fuel door - $40 Click 1 Click 2
*SOLD*Evo III Intake Manifold Powder coated Silver - $170 (bought used, never used myself, you'll need to add your own hardware to to mount the throttle body) Click0 Click1 Click2 To garbage on 6/13
Part 3:
Part2:
Part 1:
AVC-R - $165 Click
SOLD
