I am selling my galant because the galant isnt the car for me right now. I have school to finish and gas prices are too much right now. /ubbthreads/images/graemlins/bawling.gif I wish i could keep the car but i cant. The car used to be marks old car (also known as gvr4737 on the forum). He gave me the car with 10,000 on the motor in october and I put at least 10k miles on it so its at about 20k on the motor. I left everything the same that mark had on it besides changed the thermostat, and changed the oil every 2,000 miles. Only bad on the car is the corner light is broken but I am going to replace it. Everything else is good on it. GOT NEW TIRES PUT ON MAY 25 08. I could sell it around here but I would feel better if someone else with better knowledge. Now for the mods
BODY:
1991 Mitsubishi Galant vr-4
Belize Green
JDM E39a Front End conversion w/ Projector Foglights
93 LS Headlights with retrofit HID’s
JDM Sidemarkers in Amber
Carbon Fx OEM Carbon Fiber Hood
Carbon Fiber OEM wing
JDM wind/rain deflectors
SUSPENSION/WHEELS
Eibach Ground Control Coilovers
Prothane Sway bar bushings/endlinks
Enkei Evo 5 Rims 17 x 8 wrapped w/ 225 45 17" Continental Extreme Contact Tires
3000GT Vr-4 Aluminum 4 piston Calipers
R1 Concepts Drilled/slotted 99 vr4 Rotors
Custom Steel Conversion Brackets for the Brake Set up
ENGINE/POWER just got new engine put in due to knock
4G63T 2.0L 16v DOHC
1G Big Rods/2g Pistons
Mitsu 4 layer head gasket
ARP Head Studs
Mild Ported head
SCM-6152E Turbo
2G Ported Exhaust Manifold
2G 02 housing fully ported
Full 3 inch Turbo Back exhaust
Custom Fuel Rail w/ -10 AN
Aeromotive FPR
2G Maf
DSMchip Tuned Ecu
S-afc2 Fuel Management
Coil On Plug Ignition
Fully Built Transmission , Double Syncro’s strengthened Gears
Built 4 bolt LSD Rear upgraded bearings/ new ring/pinion
Rebuilt Driveshaft, new carriers.
ill get more pictures of the outside when I get it washed
BODY:
Belize Green
SUSPENSION/WHEELS
4G63T 2.0L 16v DOHC
ARP Head Studs
Mild Ported head
SCM-6152E Turbo
Aeromotive FPR
2G Maf
DSMchip Tuned Ecu
