FS: rear end and power seat belt trim pieces/pillars, some stuff free
fastfalcon94
Milton, VT
I did the 4 bolt rear end swap on my gallant, swapped in an LSD rear end, did the 5 lug swap, and manual seat belt conversion. Stuff and pics listed below. Willing to trade anything towards a set of lowering springs.
1g clear timing cover (has hairline crack where bolt holds it down, circled below. Not noticeable especially with a bolt in it) - $20 - SOLD
galant driver's pillar with dual gauge pod (needs pushpins to hold pod on, holes already pre-drilled in pillar) - $30
B pillar panels, passenger pillar, lower center pillar panels - $mak3 offer
3 bolt rear axles with cups - $25 each
And if anyone has a DSM friend looking I have a 2g LSD Rear diff for $50
Stuff is located in Milton, VT 05468, CELL 802-309-9978
Thanks - Charlie
fastfalcon94
Milton, VT
The double pod pillar is just setting on it in the picture. There were 4 holes drilled and it had the push style pins holding it on. I removed it from my car and can't figure out what I did with the pins. I'm going to be running 2 digital gauges in the ECS pod.
