FS: Radeon 7570 PCI-E graphics card
4orced4door
Raleigh, NC
Pulled this from a new Dell to upgrade. Seems like a decent basic card. It's 128-bit 1GB GDDR5, PCI-E 2.1, performed decently in the limited testing that I did. It is an OEM specific model so you won't find it on Newegg or anything. Would likely make an excellent HTPC card. The card itself is half height but the bracket is full height though. Found some specs which are below. The card is like two days old and I used it for a couple hours.
Here is the only listing for one on ebay: click
$60 shipped
</font><blockquote><font class="small">Quote:</font><hr />
AMD Radeon™ HD 7570 GPU Features Summary
650 MHz engine clock
512MB-2GB DDR3 or 512MB-1GB GDDR5 memory
900 MHz (DDR3) or 1000 MHz (GDDR5) memory clock (1.8 Gbps DDR3 or 4.0 Gbps GDDR5)
28.8 GB/s (DDR3) or 64 GB/s (GDDR5) memory bandwidth
624 GFLOPS Single Precision compute power
TeraScale 2 Unified Processing Architecture
480 Stream Processing Units
24 Texture Units
32 Z/Stencil ROP Units
8 Color ROP Units
128-bit DDR3/GDDR5 memory interface
PCI Express 2.1 x16 bus interface
DirectX® 11 support
Shader Model 5.0
DirectCompute 11
Programmable hardware tessellation unit
Accelerated multi-threading
HDR texture compression
Order-independent transparency
OpenGL 4.1 support
Image quality enhancement technology
Up to 24x multi-sample and super-sample anti-aliasing modes
Adaptive anti-aliasing
Morphological anti-aliasing (MLAA)
16x angle independent anisotropic texture filtering
128-bit floating point HDR rendering
AMD Eyefinity multi-display technology2
Native support for up to 4 simultaneous displays
Independent resolutions, refresh rates, color controls, and video overlays
Display grouping
Combine multiple displays to behave like a single large display
AMD App Acceleration1
OpenCL 1.1
DirectCompute 11
Accelerated video encoding, transcoding, and upscaling1
AMD HD Media Accelerator
MPEG-4 AVC/H.264
VC-1
MPEG-2 (SD &amp; HD)
Multi-View Codec (MVC)
MPEG-4 part 2 (DivX, xVid)
Adobe Flash
Enhanced video quality features
Advanced post-processing and scaling
Dynamic contrast enhancement and color correction
Brighter whites processing (blue stretch)
Advanced color correction
Brighter whites processing (Blue Stretch)
Independent video gamma control
Dynamic video range control
Dual-stream HD (1080p) playback support
DXVA 1.0 &amp; 2.0 support
AMD HD3D technology3
Stereoscopic 3D display/glasses support
Blu-ray 3D support
Stereoscopic 3D gaming
3rd party Stereoscopic 3D middleware software support
AMD CrossFire™ multi-GPU technology5
Dual GPU scaling
Cutting-edge integrated display support
DisplayPort 1.2
Max resolution: 3840x2400
Multi-Stream Transport
21.6 Gbps bandwidth
High bit-rate audio
HDMI 1.4a with Stereoscopic 3D Frame Packing Format, Deep Color, xvYCC wide gamut support,
Max resolution: 1920x1200
Dual-link DVI with HDCP
Max resolution: 2560x1600
VGA
Max resolution: 2048x1536
Integrated HD audio controller
Output protected high bit rate 7.1 channel surround sound over HDMI or DisplayPort with no
Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
AMD PowerPlay™ power management technology4
Dynamic power management with low power idle state
AMD Catalyst™ software and HD video configuration software
Unified graphics display drivers
Certified for Windows 7, Windows Vista, and Windows XP
AMD Catalyst™ Control Center
Software application and user interface for setup, configuration, and accessing special features of AMD Radeon products
FlyingEagle
THE Ottawa
Now installed in a 2009 Dell Studio XPS 435MT
Replaced a Radeon 3450 w/256MB or somesuch.
Mated to a Core I7 920, 6GB DDR3 RAM and running via DVI port.
Windows Experience score went from 4.0 (rest of system at 5.9) to a 5.9 all around.
Direct plug and play into the PCIe slot.
Thank you!
