FS: Race engine long block And race turbo kit complete HP proven NJ
Xcelerate
Active member
North jersey
Im about to part out my race 1g so I figure to start the thread for the big stuff first. This setup got me in to 10.8 on a roll. My last dyno was 600awhp with a street turbo setup. Now now with the new T4 turbo setup it should be around 700 which I will dyno to prove soon. My car is still in great strong running condition so whoever buys the turbo kit or engine has a chance to see it in action, I figure this way you know you're getting a legit parts!!!
Race long block $2500/pick up
Block: Ross 8.5:1 pistons, eagle rods, BS eliminated, ARP fasteners, tri metal bearings, balanced, etc. Head: BC valves (standard size, BC springs and retainers, Kelford 272 cams, OBX cam gears. H11 head studs, Greddy timing belt. All was balanced. I am revving this to 9k rpm with no problem. Head was fresh last year. It has 150 compression all 4. Less than 20% on a leak down test. Again it is still running on the car with about 700awhp. You will see and ride on my car before I take this apart. Same day deal, you must bring the cash or no ride!!!
Turbo kit complete drop in $2500 pick up
FP HTA 86 dual ballbearing turbo with T4 twin scroll 1AR 3" Vband turbine. DNP T4 twin scroll manifold. tial vband 44mm wastegate. Vband downpipe. Vband custom ALUMINUM 4" exhaust by Turbotrix. 4" intake/filter pipe. FP oil feed. All the lines and clamps. Again everything to drop in. The turbo alone worth $2.2k so this is a steal.
You can call or text me (973)901-5525. Like I said my car is still running no BS. These are all in great condition parts and proven to make high HP!!! Thanks
