FS: Part out left over parts. Make me offers everything must go.
Hondakiller
Deltona Florida
Eprom ECU. No chip. MAKE ME AN OFFER.
This is what was posted when I got the ECU.
1G EPROM ECU Modded by ECM Tuning, MD193299 (1G DSM TURBO AWD D27A MT E2T60878 EA01 7/92-5/93 FEDERAL). Caps replaced & socketed by ECMTuning. I was going to use it on my GVR4 but I’ve decided on a different management system. Additional mods done by Jeff Oberholtzer (JeffO) so car will work in a '90 dsm via addition of a small square circuit board (mounted vertically, not flat but perpendicular to the main board). These mods were confirmed by ECU/EPROM guru Steve Piette. Thomas of ECMTuning added, "That board is the Jeff-O 1990 conversion board. It's basically converting what used to be a 92-93 Federal ECU to a 90 Federal ECU. It should not have any affect on ECMLink operation, either V2 or V3... It should work fine in your GVR4 as is... the presence of that board does imply that the ECU may also have pins 6 and 14 swapped (idle switch and MAF reset)”. This ads more flexibility in case you have a 90 DSM or if you decide to sell it later.
FP manifold perfect shape. $200 + shipping
Evo lll small 16g Turbo. Had no problems with it. But some bolt broke off in the hot side. And in an out shaft play. And some side to side.
$150 OBO + shipping SOLD!!!
USDM fog light with yellow HID kit. Plug an play. The adjuster on one is bad but still lines up. An one has a little haze in it but not bad. $190 OBO + shipping
Post of when I bought them but put HID in click
Scanmaster 3 work perfect. Plug an play. $150 OBO + shipping
Greddy turbo timer all wires works perfect. No mount. Plug an play. $50 + shipping
Two EPROM 14 pin chips. Brand new never used. $100 each OBO + shipping
The Chips are basically stock tune with:
New mapping
Shutter box two step
No lift shift
Knock removed
Air cap removed
Can't remember the rest but you can have them reburied to what ever you need.
ECM link (V3 only)USB data logging cable brand new. $35 + shipping
Double piller gauge pod. $20 + shipping
World wide reman Alternator. Brand new 90 amp. $100 + shipped SOLD!!!
JDM Dash pod can make into gauge pod. $50. Shipped
Make me offers everything must go. Pay by paypal. An thx for your time.
Matt
