FS: Package deal of OEM parts.** sold **
boostx
Orlando, FL
MD115976 Engine - Camshaft & timing - Tensioner , eclipse - 2.0l 1990- 1994 $29.94
MD129355 Engine - Camshaft & timing - Tensioner pulley 2.0l 1990 – 1994 $30.56
MD365697 Engine - Lubrication - Oil pump – Seal 2.0l, dohc 1989 – 1993 $9.74
MD164533 Engine - Camshaft & timing - Tensioner adjuster 2.0l, dohc 1989 - 1990 $95.07
md040597 BEARING,BALANCER $16.93
MD372536 Engine - Camshaft & timing - Camshaft seal 2.0l, sohc 1989 - 1992 $8.94
md103722 BEARING,BALANCER $15.72
Md36597
MR984778 Camshaft & timing - Balance shafts – Belt 2.0l 1990 - 1992 $25.51
MD326059 Engine - Camshaft & timing - Timing belt 2.0l 1991 - 1992 $65.90
MD343563 Engine - Crankshaft & bearings - Front crank seal 2.0l 1990 - 1992 $15.79
mf650114 EYEBOLT,COOLING W $6.41
OEM Ignition coil, all models, 2.0l, dual cam engine $167.00
3G lifters $90
Upgrade valve springs $90
ARP STUDS 2074201 $90
FBM2519 Aeroquip AN to NPT Adapter Fittings $4.25
i will also include some other parts i have laying around 1G non eprom ECU ,injectors clips and some other stuff.
Total amount of OEM parts is $840. Pricing from JNZ
Asking $450 everything
I would like to sell everything as a package deal.
