The drivers side uses the same bushing and bracket regardless of whether it's power or non-power, the passenger side has a "lower profile" bracket and bushing.
I just wanted to make sure, because I need the bracket. But the non power bushing is still available at JNZ, so this is basically $70 for one bracket /ubbthreads/images/graemlins/frown.gif
Then you're good to go, all you need to do is install the passenger bushing, fill the bottom part of the power rack bracket with windo-weld, bolt it up, let it cure. Done.
