FS: Minjin's box o'parts
mr.mitsu
canada
I've picked out some stuff for my self but here's a full inventory for ya'll to look over /ubbthreads/images/graemlins/cool.gif
If you see anything you like pm me.
I've included part numbers and best descriptions I could.
Forgive any inaccurate descriptions or PN's.
Most shipping wouldn't cost more than $10. Obvious deal if you grab more than 2 or 3 things.
Paypal accepted and everything is BEST offer
I can take closer pics on request.
Here they are:
Left-right
turbo/O2 housing steel gasket
2x mani/turbo steel gasket 55mm opening
mani/turbo steel gasket 48mm opening
OEM throttle body/intake mani gasket MD125822
OEM oil filter housing gasket MD149370
*unknown gasket*
Left-right
OEM T25/T28 oil return gasket MD1888888
3x OEM DSM oil return gasket MR258477
2x OEM brake shims (2/pair)
2x OEM water pipe O-rings (I think) O.D.=1 5/8"
4x OEM RF axle seal (AWD/FWD) MD707184
2x OEM transfer case output seal (rear end end) MD701430
*unknown gasket*
(orange ring) OEM oil cooler inner ring MD620108
*unknown inner seal* O.D.=35mm I.D.=26mm
Oil pump gasket maybe???
OEM transfer case input seal (tranny end) MD723202
*unknown o-ring* looks like a speed sensor O-ring
Left-right
Brand new OEM wastegate for 14b or 16g
OEM rear end plug MD393530
2x unknow seals O.D.=50mm I.D.=36mm 9mm thick
Unknow seal O.D.=48mm I.D.=33mm 10mm thick
4x OEM injector seals and O-rings
Valve stem seals
3x OEM lifters MD337687
Left-right
OEM throw out bearing MD749998
2x single piston brake rebuild kits from NAPA
2x OEM tranny fill plugs MB001261
2x OEM tranny drain plugs MB001265
Thanks for looking
maroonmetallic
central WI
How much shipped for the following:
(1) OEM DSM oil return gasket MR258477
Regards,
-Shawn
mr.mitsu
canada
Wastegate and 2x transfer case seals sold!
Flakers need not pm me
CutlassJim
Manchester, NH
Your unknown gasket in the top picture is a water pump gasket. PM me a price on the fill and drain bolts for the transmission?
mr.mitsu
canada
Throw out bearing is sold!
Taking any offers /ubbthreads/images/graemlins/smile.gif
mr.mitsu
canada
Tranny fill/drain plugs & Dsm oil return gasket sold
Added: 2x EGR block off plates
Best offer!
mr.mitsu
canada
Lifters and unknown o-ring and unknown seal (both from pic 2) SOLD!!!
