I need to make some room, so I'm selling this stuff as a lot of parts. $450 OBO and you can have it all.
Please Read:
-I will not split up and sell/ship parts separately, so please don't ask...That's the whole point of selling this stuff as a lot.
-Buyer picks up, I will not ship.
-Buyer takes EVERYTHING. I don't care if you throw the crap you don't want in the dumpster on the way out of the driveway, as long as it goes with you when you leave.
You'll Get:
1) GIANT front mount intercooler. The core itself measures 11.5" x 23.5 x 4.25. From end tank to end tank, it measures 33.5". The inlet and outlet pipes are 3".
2) FWD trans. Part # KF5M332SPZV / MU5161. Unknown condition.
3) AWD trans. Part # KW5M332NPXV / LC2090. Pretty sure I busted the 3-4 shift fork. Has a welded diff, and the clusters are probably in good shape.
4) AWD trans. Part # WM332NQBM . LC4880. No diff or output shaft. The clusters are all there.
5) Trashed head with 8 bent intake valves. Caps included, good for a core.
6) 2 sets of stock camshafts. 1 messed up HKS 272 intake cam (maybe a machine shop can fix?).
7) Turbo water pipe
8) Upper suspension arms for a AWD rear subframe.
9) 3 ABS prop valves
10) 3 rear brake calipers
11) 3 slave cylinders
12) 3 bolt diff for parts
13) stock 6 bolt AWD flywheel
14) stock 1990 intake manifold. Includes all sensors, brackets and coil pack.
15) 6 bolt oil pan
16) A/C compressor
17) DSM alternator (known bad, used for core/rebuild)
18) Clutch master cylinder
19) 6 bolt dipstick and tube
20) 1G AWD passenger side outer axle shaft
21) Rear spindles (4 and 5 lug)
22) Brake master reservoir
23) GVR4 ABS rings
24) GVR4 ABS units (1 from a 1992, 2 from 1991s)
25) AEM Tru-Time cam gear for an Evo 8. Part # 23-831C
26) Stock cam gears (x6)
27) Various radiator brackets
28) EGR valve
29) Various starter plates
30) Various engine brackets (2x 346 brackets, 1x unknown trans bracket)
31) Various A/C brackets
32) Various shifter bases and brackets
33) Fuel rail (unknown year)
34) GVR4 ABS computer
35) NOS low pressure fuel pump
36) Ebay catch can
37) Rear main seal plate (for a 7 bolt maybe?)
38) Head lift brackets x2
39) Upper timing belt cover
40) Set of stock 450cc injectors
41) Set of stock 390cc injectors
42) GAB front strut bar (unknown car)
43) 1g O2 housing (no cracks)
44) Valve cover, good shape
45) 6 bolt crankshaft (thrust was cooked, use as core, scrap)
46) 6 bolt crankshaft (Mains measure at ~2.245... rods measure at ~1.770, one rod at ~1.765...Good for a core)
Please Read:
You'll Get:
7) Turbo water pipe
15) 6 bolt oil pan
16) A/C compressor
23) GVR4 ABS rings
28) EGR valve
36) Ebay catch can
