FS: Holset, o2 housing, transmission, Valve cover, poly mounts, new pics!
thedsmguy
Vancouver Washington
02 housing (probably ebay) $40 as is, no cracks, has a plug where o2 goes, I have no idea why.
English racing built trans, Double sync 1st 2nd, just took it apart and replaced 3rds sync, and a failing spider gear. This trans is in great shape. $1500
HX35 Holset. Polished housing. In great shape. Misplaced he clamps to hold it together! I was told it was a 9cm housing (NOT BOLT ON) $400
Minty HE351 non VE turbo. No pics, but I can get some $500 complete again, not bolt on.
Shaved mitsu valve cover. Nice piece, a couple busted holes for the cover, no cracks or other issues. Needs paint! $50
Poly mounts timing belt, trans, and either the front or back, cant remember. From a gvr4 $125
VR4 pedal assembly $80
dash pod $35
Rear bumper support $40
Dummy gauge $10
No cracks, no bad holes Needs paint to be much nicer $60
2g/evo3 manifold. Has crack in the bottom. $35 shipped!
thedsmguy
Complete turbo setup. Yes, ebay turbo, no it doesn't seem to have much play, just a thumbnail or so in and out. Worked fine, dyno'd at 350whp recently.
Whole setup, manifold, turbo, tial wastegate, downpipe all for $400 plus shipping (probably in the $75-80 range for shipping all of it)
English racing built trans, 1st and 2nd double synchro, taller 5th gear $1500 recently inspected great!!!
1g fmic core $100. A little beat up but not really that bad.
264/272 regrinds $150 shipped Not perfect, but not bad, these are USED but did not cause any damage to the head they were in.
Unpictured 264/264 regrinds $150 shipped as well.
Tail light center section $40
Dash pod $25
Uncracked, or stripped valve cover $50
non eprom dsm ecu $50 works.
1g fwd exhaust $250 nice setup
14b hotside nothing special, 1 broken bolt, mild cracking. Still very usable with the broken bolt removed $40
1" 5x114 wheel spacers $50
SSGdave
San Diego, CA
Quoting thedsmguy:
/ubbthreads/images/graemlins/ooo.gif HAY! would you be interested in seperating that Turbo kit. IF SO, i will take the manifold, and tial wastegate right now. LMK!
