FS: Harnesses
CutlassJim
Manchester, NH
95 Engine Harness - Everything in good shape $140
2x Galant VR4 Engine Harness - 1 has 2G injector and Maf plugs, both are pretty rough around the Tstat housing but the rest is in good shape. $120 each
Galant VR4 Chassis Harness - The engine side chassis harness. ABS plugs cut and upgraded alternator wiring. Battery Fuse box deleted and relocated into main fuse box. $80
Galant/1G ECU pigtail with the main relay and about 18" of wire. $20
