FS: Gamble ECUs
mountaineerjeff
west virginia
a working tested capped and socketed EPROM that is tested and works, but apparently is slightly different than a stock vr4 one, may be GSX, or Mirage, or rare, IDK but it worked fine 175 shipped
the 1991 eprom ecu that was capped and socketed by 1630s previous owner ran car fine before, but havent used in years so IDK. 90 shipped.
89 mirage turbo ecu, socket was removed poorly by a ricer, then I took it to a electrician to be repaired, it was socketed and a few "jumper wires" were ran to fix the places that he (ricer) damaged
electrician tested it, but I never did. 90 shipped
THESE ARE AS IS. you may be getting a steal, or you may have to send the to someone on the board to get looked at, or they may be trash. I have no way of testing them, so consider it a junkyard bargain, that may or may not work.
