FS: FIC Injectors, Walbro Pump, SAFC, ACT, BOV, ETC
OZRally
Illinois
FIC 750 injectors have roughly 10k miles on pump gas. They are in perfect condition and recently had them cleaned and flow tested. SOLD
Walbro 255 HP pump with roughly 10k miles on pump gas. Perfect working order, currently has 1g install kit on it. SOLD
SAFC works great and used when I was on a chipped ECU. SOLD
ACT streetlite flywheel. Used for 1500 miles, could use a cleaning. $150 shipped
Crushed 1g BOV. Held 26 psi with no leaks. $50 shipped
Stock 1g fuel rail. $30 shipped
Stage 3 keydiver chip. $40 shipped
Upper timing belt cover. $40 shipped
Clear front bumper light covers. SOLD
6 bolt turbo oil pan. $30 +shipping
Almost new fuel filters with brackets. $20 shipped each
Front steering wheel cover/horn. $10 +shipping
4" FP coupler. $20 shipped
Brand new 6 bolt GMB waterpump. SOLD
Lower Trim cover MB477441. $20 shipped
Left side lower cover MB521981. $15 +shipping
Right side lower cover MB521398. $15 +shipping
Lower cover harness MR550059. $20 shipped
Stock DSM valve springs with retainers. $25 shipped
Power steering pulley mounted on water pump. $15 shipped
A/C tensioner and pulley with bracket. $30 shipped
Power steering pump bracket. $20 shipped
Subaru HKS bov adapter with gasket and snap ring. $40 shipped
PM if you're interested.
Thanks,
Johnny
OZRally
Illinois
Rev Limit : 7800
Reset Octane : yes
Eliminate Fuel Cut : yes
Gauge Conversion : Knock
Stutterbox RPM Range : 4500-5500
NLTS RPM : 6000
A/C Cutout : yes
Idle RPM : 800
Injector Size : FIC 650
MAS Compensation : evo 8
High Speed Closed Loop: yes
Fuel Pressure : 37 psi
Compression : 7.8
Octane : 93
