FS: External dump s/s o2 housing..SOLD!
Jordangvr4
Nassau,NYC.
New punishment racing s/s o2 housing 38mm tail mvs v-band type
w/ext.dump tube
$220. shipped to the 48 states
SOLD!!!
lowcashleblanc
Denver CO
Is this meant to delete the factory WG and run a MVS? or is V-Band flange to V-Band flange in conjunction with the Stock wastegate? just curious cause I always thought that external WG are usually mounted on manifolds pre turbo.
Racah15
Colorado springs CO
You can do pre-turbo or at the 02 housing with a dsm style o2 housing. This upgrade replaces the internal wastegate mechanism with an external so you can run a manifold w/o provision for a wastegate like stock or FP.
lowcashleblanc
Denver CO
Very nifty, I will keep an eye out on this as I am in the market for a new o2 housing just not sure if I want to run the EVOIII or another route. GLWS
