FS: eprom burner, ostrich, palm, gauges, knock sensor
jepherz
KC, Missouri
Ostrich eprom emulator v1.0. Worked when last used. Simulates DSM rom and allows realtime burning. Maybe bigger in the chevy community. They don't sell the 1.0 anymore, but here's some info on 2.0 (http://support.moates.net/ostrich-20-overview/):
$70 shipped
Willem eeprom burner, perfect for reading or burning custom roms, worked when I last used it but I don't have a PC with parallel port anymore:
$20 shipped as-is
Knock sensor in box, I believe this is the OEM brand. Probably has 2000 miles on it:
$35 shipped
VDO EGT gauge with thermocouple and wire. Probably about 1000 miles on it. Perfect condition:
$60 shipped
Palm 3c, dock, DSM logging cable. Doesn't turn on but I assume the battery is shot.
$20 shipped as-is
Prosport EGT, Boost, and oil temp gauges. Backlights turn on on the EGT and Boost gauges, and the EGT probe doesn't look to have ever been installed. The oil temp gauge is cracked on the side and doesn't come with a sender. This is the only one that didn't seem to have a backlight when hooked up to 12v. These came in a box in a car I bought and I've never used them. Whole set of 3 gauges and EGT probe:
$80 shipped as-is.
DSM ECU circuit board header. Used to make adapter harness to Evo8 ecu or other.
$8 shipped
Photos:
