TSimage
Here's some stuff that I have that wont work with my latest change to my build which is forward facing manifold setup that will have the turbo sitting on the front bumper. My loss is your gain. The only I tems I am looking to trade are as follows:
2000cc+ injectors
AEM 5bar MAP sensor
AEM Boost sensor
44mm WGs (I need 2)
I'll ship them anywhere (buyer takes care of shipping) and I'll deal with payments with-in a reasonable time frame. NOTHING will be held unless a deposit is made. I have been burned by too many flakes on these exact items already.
Up first is my custom intercooler and high end Griffin core radiator set ups (I will do a package deal on them both together):
Intercooler-
This is the LICP for those of you running a 42r/S400 sized turbo (I'll throw it in if you need it)-
Here it is on the car:
$400
Dual pass Griffin core radiator (step above AFCO and other universal dual pass radiators) WITH an lines, fittings AND the water pipe and T-Stat housing needed to run them!
Installed-
$550 (includes Radiator, ALL needed AN fittings, SS line, Welded T-Stat AND wiper pipe!) Basically bolt it on and go!
Engine bay shot with Radiator setup-
Intercooler with bumper on-
Valve cover with -12 AN lines and Catch can-
At one point it looked like this:
$225
As I find more stuff I'll be adding it in!
2000cc+ injectors
AEM 5bar MAP sensor
AEM Boost sensor
44mm WGs (I need 2)
Intercooler-
$400
Installed-
$225
