Starting to contemplate moving on to something else, currently the car sits with stock black wagon wheels and has a fresh timing belt as of last week, always stored, driven on weekends and the occasional commute to work. It made 300hp at 16lbs of boost with alot more room to go.
right now the only bad areas of the car are a slow rear window, and damage done to the pass side door lock and door from a robbery attempt, i am currently in the process of prepping a donor door and getting it painted. the current lock is just loose with some dented areas around it, you wouldn't notice it from 5ft away, a short squack after startup, sometimes a rough idle and it could also use a brake job.(comes with good front rotors)
this car is very clean,rust free, strong street car, and was july in the most recent gvr4 calender. I really dont know if im ready to part with it yet, but am toying with ideas and could use some cash in the bank. The car will also come with everything necessary for the 4 bolt swap.
im looking for a nice daily driver, or a streetbike if your interested send info and pics
to [email protected] or pm.
thanks for looking.
