broxma
I'll be updating this single thread instead of making multiple threads from now on. I will accept offers on alot of the parts. Some parts I have no play with at all in the price. The prices do not include shipping. PM me with any questions or offers. Parts are located in Texas so shipping will be calculated from there for reference. Thanks for looking and I will update this post with any new items.
1. ACT 6 Bolt Flywheel, brand new surface - 150.00
2. Dodge Intrepid Coils(4) - 30.00
3. 92 Galant Tail light, Passenger side - 40.00
4. 2G MAS Pigtails - 5.00
5. 1st Gen 4 piston Dodge Stealth Front Calipers - 100.00
6. Cam Angle Sensors - 25.00
7. 5 lug Front Vented Rotors for 2 piston Brakes - 50.
I bought this to use in place of my Findanza aluminum flywheel only to find out the 1G ACT flywheel will not fit inside the 2G bellhousing. I had it surfaced already however. The total off the top was 7 thou, which was also cut off the pressure plate standoffs to ensure even height. I bought it needing a surface for 100, paid 65 to get it surfaced, my loss, your gain.
Dodge Intrepid Coils (4) - 30.00
I have several sets of these. I have tested the primary coils with my Fluke and I only kept the ones which came back good. They will come with the pigtail.
92 Passenger taillight. - 40.00
Pulled for someone who eventually did not need. No cracks.
Have 2 of them. One is from the Actual MAS , one is from an ignitor. Same clip though.
Dodge Stealth 4 Piston Front Calipers - 100.00
I am dropping the price on these. This is what I paid for them.
The yellow appears to be a factory color oddly enough. I may be able to bead blast the factory coating off so the buyer will have a fresh surface to paint.
These are 1st Generation Calipers. Brackets can be bought at TunersNation.
Cam Angle Sensor - 25.00
Have 3 of them. 2 on the left known good. I'll have to test the right one but I have no reason to doubt it.
5 lug Rotors for stock brakes (5 lug swap) - 50.00 pair
Purchased for dual piston conversion 1G. They have about 30 miles on them. I can get them surfaced again if desired but it isn't really necessary. Same rotor needed for GVR4 5 lug swap. Purchased from RRE I believe. Price drop on these to get rid of them. They will fit in a large USPS flat rate box so shipping will be 14ish.
Thanks for looking.
/brox
Thanks for looking.
/brox
