FS: bc 280,hx40,walbro 255,intercooler
i have a set of brian crower 280 camshafts roughly less then 1000miles on them. sold
i also have a stage 3 dsm chip for 2g mas 91oct 550cc launch control, no lift to shift, knock sum gauge sold
also a 7 blade hx40 zero shaft play very low mileage $550 shipped
evo 8 intercooler $80
walbro 255 fuel pump sold
black Venom intake manifold $350
stock evo 8 injectors 560cc $110 shipped
ebay intercooler $70 shipped, pic of it on the evo
$550 shipped for the super40
"The 7 and 6 blade hx40 is called the super40 and has the 60mm compressor inducer. This compressor flows around 69lb/min. You can get this wheel in billet style (think HTA). The non-billet wheel spools as fast as the 8blade hx40 in the bolton bep housing and has done 653whp at 40psi per the holset results only thread. Billet should spool even faster. The t3 .70 a/r BEP housing slows spool about 400rpms. But reports show a significant gain in flow per psi. So expect more power at lower boost with that turbine housing"
