FS:Baer Claw Track Brake System 450 shipped! SOLD
here ya go!
i have a complete baer setup
rotors
hubcentric rings
calipers
brackets
bolts
pads
rotors have a little surface rust. should rub right off when you brake the first time.
should fit everything with 17" + wheels
ill throw in the front prothane motormout in the backround as a bonus
verry lightly used maybe 5k tops. ill look at the exact pads tomorrow
i dont know for sure about the evo lines. they do have a ss line attached to each one with a female threaded part. click onthe pic to check it out. i hope that would work for ya. i believe the other side is a 10mm banjo bolt line on the caliper if im not mistaken.
thanks!
yup this will work if you have
1g
2g
gvr4
fwd awd click
17''+ wheels to clear the calipers and rotors
