FS: Another Garage Cleanout, Lots of Used OEM
donkeylips
Rochester, NY
*Updated 4/28/13 - Parts that are sold have been removed*
See below for pictures of everything, here is the list of parts:
-1g Intake Manifolds
-GVR4 Steering Column
-'90 Oil Cooler with lines
-EGT Probe
-O2 sensor
-Fuel Rail
-Wastegate Actuator
-Oil Return
-P/S Reservoirs
-P/S/ Pumps
-P/S Racks
-GVR4+DSM Fuel Sending Units
-2g third brake light
-1g Steering column stalks
-1g rear trailing arms+control arms+5-lug
-Front knuckles w/ 5-lug & 4-lug hubs
-3-bolt axle cups
-GVR4 parking brake cables
-GVR4 ABS wheel speed sensors
-GVR4 brake master cylinders
-1g A/C Fan
-GVR4 A/C Evaporator
-GVR4 Blower motor
-Coil Springs
-GVR4 Oil Filter Housing
I can't guarantee that any of this stuff is any good. I'll do my best to point out flaws in parts.
I can take better pictures of parts if there is any interest.
Prices are OBO. If they seem high, please let me know. I have trouble trying to guess how much shipping will cost. If you think I can ship them to you for less without taking a loss, let me know. I just need this stuff gone.
IM on the right is non-turbo (no bov port), the other one might be from a '90 turbo.
$50 shipped, each
GVR4 Steering column complete with OEM key
From 497/2000 scrapped a couple of years ago. I could probably find the entire lock set to go with it.
$60 shipped
'90 DSM oil cooler with lines and bolts
$50 shipped (ask about separating)
Coolant line for water cooled setup
$18 shipped
Used O2 sensor (didn't double check connector, not sure if it's for a 1g/gvr4 or a 2g)
$8 shipped
EGT probe (not sure if it's any good)
$8 shipped
Fuel rail with what appears to be an AN fitting welded to it. I think it's '91-'94. Comes with hose pictured.
$18 shipped
Dented wastegate actuator(from a 14B I think) and a pieced together OEM oil return.
$7 shipped each
donkeylips
Rochester, NY
GVR4 Power Steering Reservoir
$12 shipped
DSM PS reservoir - has some rust, slightly dented. Not too noticeable.
$16 shipped
1g PS pump
$28 shipped
GVR4 Sending Unit (no pump) looks like someone JB welded the pipe on there due to rust
$40 shipped
DSM Sending unit (no pump)
$40 shipped
1g PS Rack (needs outer tie rod ends)
$40 + shipping
Also ask me about GVR4 PS lines (especially front cooler line) as well as DSM PS lines
$25 shipped
1g steering column switches
$25 shipped
1g rear trailing arms (5-lug) with both control arms. NON-ABS. These appear to have energy suspension bushings. They are complete except for the axle cups, but I have some 3-bolt axle cups I can include.
These are in really nice shape.
$50 for both + shipping
4-lug hub
$27 shipped
3-bolt axle cups
$9 shipped, each
AWD DSM front knuckles with 5-lug hubs. I think they are non-abs. Axle is stuck in one (left I think) and a rotor is on the other. I didn't really try to get the axle out or the rotor off.
$10 each + shipping
Galant VR4 front knuckles complete with 4-lug hubs. 2 have rotors, 2 don't.
$10 each + shipping
Galant VR4 parking brake cables
$18 shipped, each
ABS wheel speed sensors - A complete set of 4, and 3 fronts (2 left and 1 right, or 1 left and 2 rights, I can't remember)
$5 per sensor + shipping
Galant VR4 brake master cylinder w/o reservoir
$9 shipped
Galant VR4 brake master cylinder w/reservoir as shown
$17 shipped
donkeylips
Rochester, NY
DSM A/C Fan
$30 shipped
GVR4 A/C Evaporator
$35 shipped
GVR4 blower motor (there was a nest in here at one point)
$35 shipped
Unknown springs (Probably GVR4 or AWD DSM)
$45 shipped
GVR4 OFH
$20 shipped
EGR Valve
$7 shipped
Lifters (unknown)
$10 shipped for set
blacksheep
Urbandale, Iowa 50323
So, you aren't sure if those ABS sensors are good or not? I would like a set of 4 (for each corner) in good condition that is working. Please let me know. Thanks!
donkeylips
Rochester, NY
I'm going to be working on the garage all day. I tend to be able to get things together on weekends and ship them out on Mondays (sometimes Saturdays), so now is the time to ask for more pics, etc!
