I'm selling my all original GVR4. It has 154k miles on the original engine / turbo / transmission paint, etc.
It's stock right down to the airbox and always has been. I purchased it from the original owner last fall. This car is one of few left in original condition. VIN number stickers on each body panel. Other than a few minor cosmetic issues and quirks that I call out below, the car is very decent inside and out.
It's got a lot of good things going for it - all electricals work - windows, locks, cruise, air conditioning, sunroof, rear defrost, etc. Seats are in relatively good condition for original components - I replaced the rears with factory due to sun damage. Engine runs very smoothly with good power and all gear shifts are smooth without grinding issues.
Annoyances -
Last week the driver door power lock started actuating whenever the door would get half way open. Must be a loose wire... i haven't pulled it off to check
Driveline whine - not sure if they all do this or not, but I've taken many 200+ mile highway trips with the car and it hasn't changed or seemed to matter (I replaced the fluids in the transmission and transfer case - no leaks on either)
Rough idle when starting warm - weird, but after you warm the car up fully and let it sit for 15 -20 minutes and come back out to start it, the idle is very rough and it tries to die. 20 seconds later it's fine and idles rock solid.
Horn works occassionally
Antenna is broken
Rear dogleg driver's side is missing
Car is located in Bentonville, Arkansas. PM me or email [email protected]
Annoyances -
Antenna is broken
