NateCrisman
Figured I would post it up for sale as a roller if someone wanted a project instead of parting/crushing.
I think it has 118k miles. Clean title in hand. NJ inspection till September 2011. No significant chassis rot or rust. Paint and body condition I would rate a 6 to 7. The clearcoat is starting to fail around the wing and rear 1/4 windows, the hood isn't the matching color, and it has some typical dings. Nothing major. I can detail photograph all body damage for a seriously interested party.
The shell is currently sitting on my lift, anyone interested is welcome to check it out while it's up in the air to inspect for rust or whatnot. This weekend I will likely put stock subframes, shocks, and wheels back on and roll it off the lift and into the driveway.
No sale in a few weeks = full part-out and shell crush as I normally do.
I have a trailer and can deliver the shell a resonable distance from 07825,Blairstown NJ. It will cost you gasoline at 10mpg. I'm around just about every day if anyone wants to come check it out.
Email: [email protected]
Cell: 862-251-2571 TXT prefered
Includes
[*]All wiring harnesses are in good shape. not-hacked engine harness & good plugs.
[*]5 lug hubs with 16" 1g eclipse fan wheels and usable tires
[*]Complete exterior, all lights, moldings, mirrors..ect.
[*]Full interior with choice of black cloth or light grey leather seats. (or take them both!)
[*]Headliner is new as is the carpet. interior needs plastic trim re-assembly (car comes with a big box of extra interior parts as well)
[*]Interior has been gone over with sound deadening mat.
[*]3bolt rear diff/axles included if needed, but not installed
[*]ES suspension bushings and welded solid rear trailing arms.
[*]Power steering pump and lines and power steering rack intact.
[*]Brake systems all there. Clutch hydraulics and shifter cables all there.
[*]Fuel tank, sending unit, and fuel lines are all intact. Walbro 190lph fuel pump.
[*]Radiator and stock fan & hoses
[*]Stock shocks/springs.
[*]brake calipers and rotors. (will need the rubber brake lines)
[*]I'll include some misc engine parts that will help putting it together (mounts, hoses,ect)
[/list]
NOT Included:[*] AC, Cruise control, and emissions stuff is gone
[*] Engine, Turbo system, IC pipes
[*] Trans, Xcase, clutch, flywheel, front axles
[*] ECU and all engine related electronics
[*] exhaust system
[/list]
NOTE: Pictures were taken prior to disassembly, so the aftermarket wheels, fmic, exhaust and suspension shown in the pictures aren't included with the shell.
Includes
[/list]
[*] exhaust system
[/list]
