Finally got the timing issue fixed and the car now pulls hard with the boost set at only 10psi and drives great!
Link to previous sale ad.
New paint (not the best but still nice) interior is clean and all original except for the 3 gauge A-piller pod with boost, oil pressure and water temp gauges. COLD A/C. Seats are in good shape and I just shampooed the carpet. Headliner is dirty but in good shape. Sunroof, windows and electronics including cruise control work. Speakers are 20 year old originals and could use replacing. I just installed a brand new tial wastegate and a manual boost controler also. It needs a new battery.
Will also trade for a street bike (triumph speed triple preferred) or a RWD V8 cars (LS swapped cars, T/A, camero...)
Engine:
4G63 Stroker, 2.3L, bored at 85.5 mm
Stock 100 mm crank (4G64)
MAHLE forged pistons 8.8:1 comp. #MIT130366I23
MANLEY H Beam rods, #14021-4
ACL race bearings (Main & Rod)
ARP Hardware (Head, Main and Rods)
All new timing components
Balance shaft delete
Rebuild Head with 3mm lifters, 3 layer metal head gasket
Exhaust header manifold w/external wastegate
Turbonetics T04E vband 60 trim turbo, 3" inlet- No shaft play
TIAL 38mm wastegate
Turbo XS manual boost controler
FMIC 12x26 w/3" inlet and outlet
Custom IC piping by 4GPerformance
COP Ignition
2.5" Exhaust with high flow cat and dual tip muffler.
New water pump and alternator
EVO 3 Mass w/upgraded ECU chip
Walbro 255 lph fuel pump
Rear Battery Conversion
Transmission:
Stock W5M33 5 Speed
SPEC Stage Two clutch and pressure plate
Chassis:
New Monroe struts
Cross Drilled/Slotted Rotors-F&R
High Performance HAWK pads-F&R
4WS
Exterior:
Sunroof
No rust or Dents
New paint - Orininal color - Summit White
Interior:
Leather seats - very good condition, slight wear, but no tears
Carpet typical fading, new floor mats
Dash and door panels - excellent
Glo-shift pillar guage set - Water, Oil and Boost gauges
Radio- Mits AM/FM Cassette w/equalizer
Extra's not installed yet, included with car:
AFPR with hoses
680 Injectors
Dsm chip for 680's, evo maf, 8200 redline
Metal radiator
symbroski shifter bushings
Engine:
TIAL 38mm wastegate
COP Ignition
Transmission:
Stock W5M33 5 Speed
Chassis:
New Monroe struts
4WS
Exterior:
Sunroof
No rust or Dents
Interior:
AFPR with hoses
680 Injectors
Metal radiator
