FS: 92 Galant VR4 425/1000 Davenport, IA $13000.00 SOLD
Terry Posten
Davenport, Iowa USA
I have owned this car since Dec of 2003. I started with it as a bone stock car with 113,000 miles at a bank repo lot. I have spent 9 years bringing this car to this point. It is a 9.8(maybe better) out of 10 both inside and out. I am extremely anal and nothing has been left to chance. I daily drove it for 5 years before getting really serious about the restoration. In the last 4 years, it has not seen snow/ice and only got wet to wash it and getting caught in the rain at MOD one year.
I would not hesitate to drive this anywhere. As you can see from the info below. It is running a very safe "street setup" tune of 361whp at only 18psi on Shell 93 octane gas.
I am asking $13,000 firm. That is $2000 less than appraisal value and that was before the interior restoration/dynomat work, EVO III tranny, drive shaft, engine bay, radiator, piping, battery, and ECMlink V3 w/SD setup dyno tuned work.
This car is insured for $20,000 at Hagerty Insurance (costs $400 a year). It is worth every penny.
If you have any questions, email me at [email protected] or PM me here with your phone number and I will call you.
The only "bad" thing, drips about 3 drops a month from the oil pan gasket.
This is one of the best 5 examples in the USA. Below is the exact "Members Showcase" thread with current pictures and examples of what has been done extra.
Body:
New paint by Tom Lindle
Factory Summit White
New emblems
New chrome
White handles
Rustoleum oil based flat black undercoating
Complete engine bay restoration
Looks like a new car
Mods:
Motor Fully built by Class One Inc
2.3L stroker with cryoed and MicroBlue coated bottom end
Stainless Steel O-ringed deck
Eagle rods
JE .40 pistons
ARP hardware throughout
3G lifters
BC 280 cams
Sleeper stock intake mani that has been cut, knifedged, and re-welded
Throttlebodys.com rebuilt 65MM TB
Stock oil pan with -10 drain fittings
Custom 10"x10" oil cooler w/8" fan and -an10 braided lines
PLX wideband O2 with gauge inside cabin
Mitsu timing parts
Rebuilt ported head
Supertech springs
Profain motor mounts
1G style aftermarket Radiator w/twin 12" fans custom setup for 160 degree operation
Fuel
RC750 injectors
255 Walbro pump rewired with 10Ga wiring
SARD AFPR with Marshall mechanical 100psi gauge underhood
Tranny/Driveline
Headdynamics rebuilt tranny and T-case
EVO III spec tranny (double syncros on 1,2,3,&4, close ratio 3/4, the works)
ACT Chromemoly flywheel
Clutchnet sprung 6 puck w/3X PP
Mitsubishi Diaqueen
Brass shifter bushings
TEL shifter
New master and slave cylinders
4 Bolt LSD rear
Red Line Heavy Shock proof in T-case and rear
Complete Drive shaft rebuild using all OEM parts
Forced induction
PTE SC6152RSP A/R .70 ball bearing
FP Race exhaust manifold
JGS external wastegate
Custom stainless steel down pipe (Head Dynamics one-off work of art)
FMIC and piping from Extreme Turbo Systems
Forge BOV (vented to atm)
4 Bar Speed Density
GM Intake Air Temp sensor
4" aircleaner setup with a cold air box
Lower Shores Performance MBC
3" turboback exhaust w/o cat
Brakes/Tires/Suspension
Ceramic pads on all 4 corners
New rotors - 5 lug Stop-Tech cross-drilled/slotted all around
Yingling 215/45/17 ZR Ultra High Performance rubber
Enkie 2 piece OEM rims (won at MOD 08)
Full ABS delete
New flexible brake lines
H&R Galant VR4 specific springs
KYB GR2 struts in rear
Monroe Sensa-trac struts in front
Whiteline front swaybar
Whiteline rear swaybar
Whiteline rear strut tower brace
Cusco front strut tower brace
5 lug hubs
All new OEM wheel bearing/seals/lug nuts/lug studs
Electronics
PLX WBO2
Marshall Oil Pressure gauge
Marshall Fuel Pressure gauge
Marshall Boost/Vac gauge
Marshall Volt gauge
ECU capped and socketed
ECMLink full V3 w/speed density setup
Relocated full size battery to firewall
There is plenty more but this list is long enough.
Dyno graph on 6/14/2011
Video of a second gear pull on 6/14/2011
Pictures taken in July 2009 pics:
Pictures taken in March 2012:
Pictures taken in July of 2011. New engine bay paint, speed density setup, EVO III transmission, new intake piping, radiatior setup, etc...
Pics of some of the custom work done by Chris Beran and other custom work.
Gauges change color with dash lights
Curtis rails (before new undercoating)
Flip4G63
Abilene Tx
/ubbthreads/images/graemlins/jawdrop.gif i think i just creamed a little.....
glws! worth every penny imo
Terry Posten
Davenport, Iowa USA
Quoting turbowop:
Reason for sale? /ubbthreads/images/graemlins/confused.gif
Need new project, anything more this car needs is going to be a "personal choice" and not a need. I am ready to start looking for something else and I don't have the garage space to keep this and another "labor of love".
I hope this car goes to someone as loving as you have been. That's a great looking galant. Just for clarification, there is no radio/audio in there?
Terry Posten
Davenport, Iowa USA
Quoting PearsVR4:
There is no radio, but there is a 4 channel amp with IR remote and an Ipod cable (actually has 3 stereo RCA inputs). Connected to the factory wiring for speakers.
Not the best clarity but is decent and works well.
Terry Posten
Davenport, Iowa USA
No AC. It worked fine before I removed it.
Could be re-installed but the radiator and oil cooler would have to be modified.
All electrical for it is still intact.
bustedsm
Ripley, Tennessee
I want this so bad, but I highly doubt you'd be up for a straight up trade with my Typhoon. /ubbthreads/images/graemlins/bawling.gif
Ben
Lubbock, Tx
I know you said no trades, but it doesn't hurt to ask. A 1960 mini cooper?
Terry Posten
Davenport, Iowa USA
Quoting Ben:
Sorry, no.
However, post up yor Mini in Anything Goes. I would love to see it.
Ben
Lubbock, Tx
It belongs to a guy I work with. He just traded a deuce and a half RV for it. haha
