FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated May 10th 2022
pot
Fayetteville, NC
For sale are stock parts removed from a 158K Summit White. Everything offered is in used but serviceable condition.
All parts prices include PayPal fees & Shipping Costs for CONUS based transactions unless noted otherwise. I accept all payments via PayPal to: [/b][email protected][/b]
If interested please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
ENGINE
Engine Mount Bracket (Rear) $20.00
Alternator Bracket $8.00
Cam Gear $15.00
Crank Pulley Bolt & Washer $8.00 *2 available
Crankshaft Sprocket B $20.00
Flange $3.00
Silent Shaft Sprocket $15.00 each
Water Pump Pulley Set $15.00
Throttlebody Ground Tab $3.00
Spark Plug Wire Guide $3.00 each
Aircan Vacuum Line Mounting Bracket $15.00
EGR Valve *3 Galant/1g Available $15.00
Alternator Relay part no MD113566 $12.00
Alternator Pivot Bolt $8.00
Oil Cap $8.00 each *3 Available
Fuel Pressure Regulator *1g Non-Turbo $15.00
Fuel Filter Banjo Bolt $3.00
Banjo Bolt (Oil Feed on Turbo) $5.00 each
Banjo Bolt (Coolant Feed/Drain on Turbo) $5.00 each
Fuel Purge Control Solenoid $20.00
Fuel Purge Solenoid Valve w/ Wiring $20.00
Fuel Pressure Solenoid Valve Wiring $8.00
EGR Control Solenoid Wiring $12.00
Oil Squirter Check Valve $8.00
Fuse Box Fuse *Complete set for engine bay $5.00
BODY
Headlight Relay part no MB183865 $8.00 each
Lower Radiator Hose Clamps $1.00 each
Washer Reservoir Hardware Set $3.00
Hood Switch (Alarm) *Rubber cracked $3.00
Trim Panel (Passenger Side) $3.00
Fender Bolts *Summit White $3.00
Horn Alarm $15.00
A/C Condenser High Relay $8.00
MAF Intake Hose Clamp $2.00 each
ECU Harness Retainer $3.00
Timer, Defogger Delay part no MB572253 $8.00
Fuel Filter Bracket *2 Available $3.00 each
EGR Line Retainer $1.00 each
Downpipe Mount $3.00
Exhaust Hardware $1.50
Radiator Bracket Bolt Set $5.00 *Used, four bolts
Side Skirt Hardware Set $2.00
Wheel Well Retainer $.50 each
Galant GSX 3rd Brake Light $20.00
Fuel Door Hardware $1.00
Fuel Door Lock Cylinder Retainer $.50
Tailight Cover (Left Side) $10.00
Tail Light Center Section *Passenger side, slight crack $12.00
License Plate Lights $20.00 for pair
Trunk Lid Bracket $15.00 for pair
Trunk Molding $25.00
Trunk Lid Striker $3.00
Trunk Striker Bolts $2.00
INTERIOR
Fuse Panel $20.00
Fuse Puller (Interior Fuse Block) $1.00
Footwell Carpet Clip Set $2.00
Hood Release Assembly $15.00
Defogger Switch $ 15.00
Dome Light *Sunroof model $40.00
Sunroof Control Motor *part no MB549075 $20.00
Sunroof Power Relay part no MB627895 $8.00
Sunroof Adjust Plate $1.00 Each
Radio Antenna Cable $15.00
Buzzer Switch, part no MB802356 $8.00
Ashtray Cover $2.00
HVAC Selector Tab $1.00
HVAC Vent Tab $1.00
Door Card Handle $5.00 each
Door Handle Cover *Rear Driver side sold $3.00 each
Door Light with lens $5.00
Door Sensor $5.00
Control Unit, Door part no MB543647 $15.00
Driver Window Switch Cover $5.00 each
Driver Window Switch Cover $3.00
Window Switch $15.00 each
Door Sill Hardware $2.00
Armrest Stay $15.00
Arm Rest Hardware $1.00
Seat Trim Bolt Cover $1.50 each or $20.00 for full set
Trunk Trim Access $8.00
Tool Bag $8.00 each
SUSPENSION & STEERING
P/S Pump Mounting Hardware Set $2.00
Cruise Control Cable mount *Mounted on Passenger Side $2.00
Front Control Arm to Subframe Bolts $10.00 *Per pair
Front Subframe Lower Plate & Stopper $5.00
Gusset Plate Bolt Set $12.00
Front Steering Rack Brackets $20.00
P/S Line Bracket $3.00
Rear Suspension Mount Bolt *1 left $8.00
DRIVETRAIN
Driveshaft Hardware Set $3.00
Slave Cylinder Mounting Hardware $1.00
Shifter Bracket Mount Hardware (Lower) $1.00
Shifter Bracket Mount Hardware (Upper) $1.00
Transmission Mount Hardware $2.00
BRAKES
ABS G Sensor (Rear) $20.00
ABS Sensor Mount (Front) $3.00
ABS Ring (front) $20.00
ABS Dust Shield $20.00
Parking Brake Stay $8.00
Brake Fluid Level Sensor Wiring $5.00
Brake Fluid Reservoir $20.00
Rear Brake Caliper Bracket Set *Powder coated gloss black $40.00
Quoting Pot:
For sale are several stock parts removed from a 158K summit white '91 gvr4. Shipping and paypal charges have been included hence my prices. Shipping charges for OCONUS transactions will be handled on a case by case basis.
I will be continually adding parts over the next twenty-four hours therefore if you don't see something your interested in feel free to PM me.
First PM first served and thank you for your time.
28.) TURBO WATER PIPE *2 AVAILABLE $20.00
Looks like the water pipe in the background is a non turbo pipe. If this is true I will take it. PM sent
KiNgMaRtY
Corona, CA
What kind of condition is the power steering rack in? Mileage? Complete with tie rods? PS pump? Do you have the hose the goes from the fuel door to the tank?
PM me if you do
AWDnoobie
Alberta, Canada
Hey Pot, do you still have the rear steering rack? If so what kind of shape is it in, looks kind of rusty in the picture. Id like to get a 2nd one to rebuild
chrisfullwood
bartlesville, ok
Do you still have the air conditioning system on the car? if so does it work, if not, is it complete and how much /ubbthreads/images/graemlins/smile.gif thanks.
Chris
