FS: '91 Gvr4 Partout (560/2000) NB *Updated May 10th 2022
pot
Fayetteville, NC
FS is nearly everything from a 1991 Galant vr4 badge number 560/2000.
All parts prices include PayPal fees & Shipping Costs for CONUS based transactions.
I accept all payments via PayPal to: [email protected]
If interested please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
Engine
Engine Mount Bolt *Driver Side $3.00
Resistor Pack $40.00
Throttle Cable Guide $3.00
Body
Horn Set $8.00
Rear Door Molding $50.00 each *Passenger side sold
Hood Bumper Set $5.00
Hood Latch $8.00
Hood Release Cable $10.00
Hood Cable Guide $5.00
Hood Alarm $5.00
Wiper Arm Set *Driver Wiper Foil is not included $30.00
Hood Cushions $3.00
Hood Hinge Set $15.00
Air Inlet (Passenger Side ) $8.00
Cowl Trim $8.00
Relay Set *Engine Bay $20.00
Timer Unit Defogger $8.00
Alternator Relay $8.00
Door Lock Relay $8.00
Rear Window Regulator $50.00 *Rear Driver side sold
Door Ajar Sensor Set $15.00 or $3.00 each
Door Wiring $15.00 each
Door Striker $3.00 each
Outside Door Handle Base $10.00 each
Outside Door Handle Cover $3.00
Front Door Lock Actuator & Latch Assembly $20.00 per door
Rear Door Lock Actuator & Latch Assembly $20.00 per door
Fuel Lid $15.00
Fuel Lid Hook $3.00
Driver Quarter Glass $35.00
Passenger Quarter Glass $35.00
Fuel Pump Wiring Cover Set $8.00
Trunk Wiring, Part no MB543015 $40.00
Rear Passenger Tow Hook $20.00
Interior
Passenger Dash Speaker Cover $20.00 * Driver Sold
Chassis Control Module $25.00
Foot Rest $8.00
Gas Pedal $30.00
Brake Pedal $30.00
Clutch Pedal $60.00
Brake Light Switch $8.00
Clevis Pin $1.00
Front Skuff Plate $5.00 each
Rear Skuff Plate $5.00 each
Door Card Retainer $1.00 each
Interior Door Handle Backing Set $3.00 each
Interior Door Pull Handle 8.00 each
HVAC Control Trim $25.00
Parking Brake Adjuster $10.00
Radio Antenna Cable $10.00
Buzzer $5.00
Center Console Side Trim $12.00 each
Doorcard Light Set $3.00 each or $15.00 for all
Center Console Trim $12.00
Glove Box Light $5.00
Control Unit Auto Seat (MB 617345) $20.00
Armrest $40.00
Rearview Mirror $15.00
Window Switch Set $5.00 each
Dome Light (Non-Sunroof) $20.00
Emergency Brake $30.00
Hood Release $3.00
ETACS (MB852353) $40.00
Passenger Door Speaker Cover $12.00
Front Lap Belts $15.00 each
Rear Shoulder Belt $15.00 each
Rear Speaker Cover $12.00
Trunk Trim $8.00
Trunk Dome Light $3.00
Trunk Trim Striker $20.00
HVAC
Cooling Unit $60.00
Blower Motor $50.00
HVAC Control $30.00
Heater Unit *Does not include Heater Core $60.00
Auto Comp Controller (MB276780) $12.00
HVAC Adjuster Tab Set $2.00
Harness, A/C Thermostat part no MB 276781 $15.00
Drivetrain
Clutch Master Cylinder $15.00
Clutch Line Bracket $5.00
Flange Yoke to Differential Hardware Set $2.00 plus shipping
Brakes
Front Driver Brake Line $15.00
Rear Brake Line $8.00 each
Brake Fluid Reservoir $15.00
Low Brake Fluid Sensor $8.00
Non-ABS Brake Lines $40.00 *Missing Passenger Side
ABS G Sensor, Front $20.00
ABS G-Sensor, Rear $20.00
Steering & Suspension
Front Control Arm Clamp $15.00 each
Front Swaybar Mount Set $10.00
Endlink Set $5.00
Rear Crossmember Bracket Set $15.00
Rear Strut Mounts $15.00 each
Lower Control Arms $20.00 each
Rear Swaybar Bracket Set $5.00
Rear Upper Control Arms $20.00 each
I need a very tiny part. It's a floor plug that is on the floor board behind the passenger seat carpet. It's about the size of quarter.
Toago
Member
Calgary Canada
please let me know if you could ship a working rear window defrost switch up to Canada, ideally through Express shipping haha!
