FS: '91 Galant VR4 BG Race Setup #19/2K, 17K, Ont.
IanM
CFB Petawawa, Ont
Not really something I intended on doing- I'm selling my VR4 in order to raise funds for an S2000.
Here we go:
1991 Mitsubishi Galant VR4
#19/2000
Have the Spare, Key fob, Valet, Leather owners manual, and Cup holders.
Belize Green
160,000 Miles
4 Bolt Rear LSD
4WS Disabled (The right way)
No Rust (Proofed every year)
Mint Interior
All Clean OEM Glass
Sunroof (Working, No leaks, and comes with complete spare)
Summer tires and Winter tires both with Wagon Wheel Rims (2 Sets)
Whiteline Front and Rear Stabilization bars
100% Stock otherwise.
Heres the fun part- It comes with;
Fully built 4G63:
Carrillo Rods
ARP Main studs
ARP Head studs
New OEM front cover
New OEM rear main seal
Balance shafts eliminated
Ferrea SS Valves
Kelford 272's
BC Valve springs and Titanium retainers
Kigglys oil valve train pressure regulator
HKS timing belt
HKS cam gears
All brand new OEM timing bearings
ACL race bearings
Polished and balanced crank
OEM new balancer
small amount of port work done mostly cleaning up casting flaws
Bored,decked, line bored and head decked
Shep Race Trans Stage 4,
With every upgrade He offers.
And;
JMF polished Drag intake manifold flanged for stock throttle body
Coil on plug setup I just installed 4 brand new OEM intrepid coils
S90 billet throttle body
JMF coolant over flow tank
JMF breather / catch can with valve cover fittings and hoses
JMF GVR4 Top mount T4 twin scroll exhaust manifold, Both dump tubes and 3" down pipe are included, every thing has been JetHot coated with their 2000f black high heat coating
Tial 44mm V-band wastegate colour is purple
Tial Q blow off valve color purple
JMF PC680 small battery kit
Avid billed mount set all 4
Zaklee corp clear timing belt cover small notch cut in back to clear -10an fuel lines
Fuel System - Full Blown 2 X 255LPH Walbros with all braided lines to the Magnus Fuel Line, Fuel Lab filters, AFPR and back
Radiator Setup - Scorocco unit
JMF 3.5" SS exhaust uses V-bands, Also had a 3.5" dump made to replace exhaust for race use
Carbon fiber Speaker Guage Holder
QuaterMaster Twin Disk
Forced Performance 35R HTA Turbo (New Hotside Needed)
JDM Spec Cams
Mitsubishi Roof Rack
Extra Grilles
Extra OEM Interior parts
Tons of extras
Car Cover
My intent was to build a Race VR4. This is a killer setup.
I can and will help with delivery (over Christmas leave)
I live in Ontario Canada, don't let that discourage you, I am motivated.
I will NOT part out.
I'm looking for $17,000 CDN
Or trade for a Low Mileage S2000 (red interior is must)
My name is Ian, call or text (613) 401 8793
dammitjim
WI
GLWS. I had an S2000 before this car, if you have any questions on them PM me. If you get an 00-01 make sure the oil banjo bolts are replaced. 00-03 make sure the valve retainers are replaced.
mistaVR4
Boulder, CO
About $500 less. Sounds like a super well built car! Probably the nicest Black VR4 around! GLWS.
mistaVR4
Boulder, CO
I always get those mixed up. Could be my monitor settings I suppose. Either way great looking car, and even better build! Shouldn't last long.
IncorpoRatedX
Arizona
Mike, try reading once and a while, he explains that's where the engine came from in his post.
it's a good thing im not a mod, i'd be deleting your posts left and right. /ubbthreads/images/graemlins/devil.gif
IanM
CFB Petawawa, Ont
I forgot that it passes all safety inspection, and emissions testing. Air conditioning blows cold, and everything works down to the green dash/radio lights.
I'll even include my VR4 Galant model, unopened from overseas. /ubbthreads/images/graemlins/smile.gif
Ian M
toybreaker
iconoclast
Please read the rules for this section.
7. You are limited to 1 "bump" of your thread per week (a bump is replying to your own post with the specific purpose of moving it to the top of the post list). If you insist on bumping your thread all the time it will be locked. Please give everyone else with posts that have interest and activity their rightful place.
Thanks!
