FS- 91 Galant VR4, #212, MD
xelsworthx
New member
Hi all. So I am selling my GVR4. i have put A LOT of time and money and love into this car but life changes and well we all know how that goes, so I'm going to tell you a little about the car then post some pics of the car and build and mod/ repair list. The car is 99% mechanically sound other than tires and a tune, starts and runs but is very rich and i just have not plugged in the ECMTuning software on my laptop and corrected it. The turbo drain also needs to be redone (gasket is leaking at the pan). She needs a paint job, the only exterior rust on the car is at the hood above pass headlamp, never been crashed, nor is there any major dents. there was some rust under the car but i have painstakingly repaired and undercoated everything that i could get to.. I really have repaired replaced every system on this car. fuel, brakes, driveline, ect. PM me or email me @[email protected] if you have any questions.
I am asking $5000.
FUEL
- cleansed and re lined fuel tank. Inside and out (turned out great)
- new hardline return
- fuel tech/ dietchworks stainless braided kit with 300lph pump w reg
-800cc injectors
-del evap system
BRAKES
-ABS del
-SS lines
- ss hard lines rear (every brake line is new SS)
- new master cyl
- all new ss hard lines
- new pads rotors (power stop)
- new calipers (4) oem DSM rear (could not hook up e brake)
Turbo
- big 16g
- new feed and drain
- blasted oem manifold painted w high temp paint
- plazmaman fmic kit
-turbo smart bov
-turbo smart manual boost controller
-Turbo smart boost gauge in glove box (have bezel not mounted)
Drive line
- Sachs oem clutch re surfaced flywheel
- new wheel bearings
- new slave cyl
- new drive shaft u joints and bushings
- new ball joints
- new sway bar bushings
- new front reman axles
- new sway bar links
- shifter bushings (not installed)
Misc/ other
- new starter
- new coil packs
- new alt
- new rack and bushings
- new timing belt Oem
- reman cyl head (was installed when I got the car, super clean inside cyl head)
- painted black wrinkle valve cover w new gasket.
- new grill ( oem non vr4) still have stock.
- tons of surface rust repair/ coating under car)
- led headlamp bulbs
- 4ws del
- ecm tuning ecu (full kit)
- new rad/ fans
-3 inch down pipe with new o2 housing w open WG dump
- all fluids changed with redline or motul fluids
I’m sure I’m missing some some stuff
thumbnail (2).jpg NDRQ0570.JPG IMG_3769.JPG IMG_3751.JPG IMG_3748.JPG IMG_3747.JPG IMG_3746.JPG IMG_3745.JPG IMG_3744.JPG IMG_3735.JPG IMG_3729.JPG IMG_3725.JPG IMG_3724.JPG IMG_2763.JPG AHLX9337.JPG IMG_3771.JPG IMG_3740.JPG IMG_3732.JPG
