FS: 91 Eclipse GSX, Mt. Prospect Il. $2250.00obo
Lancer99
Somewhere over the rainbow
My dad is selling his 91 GSX, manual transmission, with 88,xxx miles on it. It's green exterior and light tan interior. It's not the best of shape but it runs and drives. Everything is stock on it and whoever bought got every option you can get on it at the time. It has factory cd player, abs, the pop up sunroof, power antenna, tow hitch with wiring harness, leather seats. Please contact my dad, Raphael at 847-224-2446 text or calls
I'll start with the good:
Rebuilt transmission by Jack's Transmission just the stock rebuild
Rebuilt clutch pedal assembly done by Shep
Act 2100 clutch about 10,000 miles on it
New front rotors and pads
new left front ball joint
New outer tie rod ends
Timing belt, water pump and idler pullies were replaced about 500 miles ago
A/C has been retro fitted for the R134A freon
New condenser and dryer
All four new tires
The Bad:
It has rust on the passenger front fender, bottom of the rear wheel wells
Paint has the usual faded clear coat
both door mouldings have fallen off
To get the a/c working you need to install the belt and tensionor and recharge it with the r134a freon
Power ant. mast is broken off
There is a coolant leak, hoses I believe
There is a oil leak but can't tell from where, either the oil pan or the turbo oil return line gaskets
left front wheel bearing going out
drivers front seat is ripped apart
headliner is sagging and ripped
