I bought this car in December. Fixed a lot of suspension components, new tires, wheel bearings, ball joint, tie rod etc. This is Nate Pharr's old car.
90 Mirage
4g63 Swap rebuilt
White
Fuel:
Intake supra pump
SS lines all the way up and back
AFPR
780cc PTE injectors
Driveline:
Rebuilt tranny
quaife lsd
ACT2600
Streetlite flywheel
Turbo/IC/Exhaust:
Hard pipes
FMIC
60-1 AGP turbo
SARD BOV
SFP tubular manifold
3" Exhaust with a stock muffler where the cat was there is a manual cut out. Car is very quite until you remove the cut out.
Suspension:
15" wheels said to be old RX-7 wheels
2x new wheel bearings
adjustable sleeve type coilovers in the front AGX's in the rear
Roll cage 6pt
Strut bar in the rear
MISC:
Dsmlink v2
Autometer boost guage
Red top battery
Cd player
new o2 sensor
I am sure I am forgetting some stuff. I got this car off Harol and I have been daily driving it. I currently have a boost leak that needs to be taken care of and the TB should either be rebuilt or replaced. Also needs an alignment. The leak might be the BOV since its a knock off greddy I don't trust it. Car runs great in vacuum but not so great in low vac low boost. I am probably going to fix these issues this week. Also grinds 5th and reverse, might be a shift linkage problem, does not always grind.
The car would make a perfect drag project but I have found it to be a fine daily driver if you don't mind the cage. Not a great snow car of course due to power/weight/FWD. If you add in cut outs it would be a great two seater. Currently has a back seat but mostly for show due to it being so low the rear wheels rub with too much weight. This can be fixed but rolling the fenders but I don't plan on packing the car full of weight.
I am selling for one reason only and that is to buy a Evolution. I will be taking pictures tomorrow and I will update this thread as issues get fixed or new parts added.
Asking price $5500.00USD
I will be getting updated pictures ASAP!
90 Mirage
4g63 Swap rebuilt
White
Fuel:
Intake supra pump
AFPR
780cc PTE injectors
Driveline:
Rebuilt tranny
quaife lsd
ACT2600
Streetlite flywheel
Turbo/IC/Exhaust:
Hard pipes
FMIC
60-1 AGP turbo
SARD BOV
Suspension:
Roll cage 6pt
MISC:
Dsmlink v2
Red top battery
Cd player
new o2 sensor
