FS: 885/1000 $6000 Atlanta !!!!!SOLD!!!!!
Vman911
Douglas county, Ga
1992 Galant VR4. 885/1000 is up for sale. 176K on body. 2,200 on motor. $5,800
link to pics:
Engine:
4G63 Stroker, 2.3L, bored at 85.5 mm
Stock 100 mm crank (4G64)
MAHLE forged pistons 8.8:1 comp. #MIT130366I23
MANLEY H Beam rods, #14021-4
ACL race bearings (Main & Rod)
ARP Hardware (Head, Main and Rods)
All new timing components
Balance shaft delete
Rebuild Head with 3mm lifters, 3 layer metal head gasket
Exhaust header manifold w/external wastegate
Turbonetics T04E vband 60 trim turbo, 3" inlet- No shaft play
FMIC 12x26 w/3" inlet and outlet
Custom IC piping by 4GPerformance
COP Ignition
2.5" Exhaust with high flow cat and dual tip muffler.
New water pump and alternator
EVO 3 Mass w/upgraded ECU chip
Walbro 255 lph fuel pump
Rear Battery Conversion
Transmission:
Stock W5M33 5 Speed
SPEC Stage Two clutch and pressure plate
Chassis:
New Monroe struts
Cross Drilled/Slotted Rotors-F&R
High Performance HAWK pads-F&R
4WS
Exterior:
Sunroof
No rust or Dents
New paint - Orininal color - Summit White
New wheels and tires with less than 1,000 miles.
Wheels - Xtatik 17x8 10 spoke
Tires - Autoguard s900 - 215/45ZR17 Speed rating-W, Load range-91
Interior:
Leather seats - very good condition, slight wear, but no tears
Carpet typical fading, new floor mats
Dash and door panels - excellent
Glo-shift pillar guage set - Water, Oil and Boost gauges
Radio- Mits AM/FM Cassette w/equalizer
Extra's not installed yet, included with car:
AFPR with hoses
680 Injectors
Stock Rims
Dsm chip for 680's, evo maf, 8200 redline
Metal radiator. Plastic one not goiong to make it much longer
highspeed
AFCRAPISTAN
Vinny is a stand up guy, and he absolutely knows what he is doing.
I pm'd you on sedsm.org, lets work something out.
beigetsi
Active member
st.petersburg,fl
NOOOOOOOOOOO!!!!!!!!!!! I have been trying to save money. GL on ebay I must warn you I will be praying you dont sell it. If you dont hopefully I can reach your price by then. BUMP BUMP For a bang for buck GVR4.
Street Surgeon
Omaha, Nebraska
This is a kickass deal, for reference I bought 501/1000 for ~5100 bucks or so and though the car was clean the motor/trans were on their last leg. Good luck with your sale!
Vman911
Douglas county, Ga
didn't make reserve... I'll take 5100 with the stock rims on it. Rims are included with full price of car. They got no tires on them. So for 5100 I'll put tires on them.
1gFWD
I saw you had 1667 up as well... interested in talking about a trade on that front?
