FS: 6-bolt long block SOLD!!!
4wheelsqueal
Shawano,WI
Complete long block. Stock bottom end with 130,000 miles. Still has balance shafts installed in it. Rebuilt head with about 500 miles on rebuild. Reground valves, new valve seals, 3g lifters, new cam shaft seals, new arp headstuds, mitsu mls headgasket, new valve cover gasket, new intake manifold gasket, new oem mitsu timing belt tensioner, new oem mitsu idler pulleys(timing and balance shaft), good condition lower timing cover(not pictured). Comes with stock intake manifold but NOT fuel rail, throttle body, coil pack, power transistor(these are in the pictures but not included) Motor pretty dusty from sitting in the shop for a while. Was slated to be installed in my green vr4 shell but sold all the galants so dont't need this. had 165 compression across the board when pulled.
$650.00 for long block picked up
$750.00 with throttle body, fuel rail, 450cc injectors, coil pack, power transistor. picked up
Would ship but buyer wiuld pay all shipping fees.
