FS: 4 bolt LSD rear with axles cups etc
curtis
Clarksville TN
Dirty and needs a good pressure washing (if it warms up more today I'll do that then take pictures after I drain the fluid out of it) but no rips in the boots and ready to put in. Comes with both axles, cups, nuts for the hubs and the 8 10.9 bolts for the axles to bolt to the cups. Also comes with bolts to the mustache brace and side bolts. Still have the subframe if you need something off of it as well.
$250 + actual shipping...... shipped to a business and paypal'd as a gift....It's heavy and I'm sure over the 70lb limit fed ex has going to a residence so we'll need a business address.
shipping will be fex ed with tracking number sent as soon as I see payment has been made.
paypal is [email protected]
Also for the guys overseas the LSD can be taken apart and fit into a USPS medium flat rate box, then the axles and cups can be boxed up in a separate box. Flat rate to NZ was like 50 or so and axles probably 75 you'll just have to use your ring and pinion and housing. Yes I've done this before.
Thanks Curtis
