FS: ?/2000 1991 galant vr4 Omaha NE $7500
gaylantvr4
Omaha ,NE
I am at the point in my life where i just want a new car so this means i will have to give up my vr4. The car is in good condition and has it's flaws but over all it sould get a 7 out of 10. The roof skin is warped witch is it only major flaw but not really noticable. the car has been graged for winters since i have owned in and has no body rust. Here is a list of its modifications. I have problity forgot some small other mods but it should all be there in geneal. My price is 7500 firm i have thousands of dollars and man hours invested into this car.
Block
2.0l 1G 7 bolt
Crower rods
Probe pistons W/tool steel wrist pins
Mbc cad kit
Alignhoned
Arp main studs
Balance shaft removed
Acl race bearings
Evo 3 oil filter housing w/external cooler
Mach v alunium pully kit
2g power steering pump
Head
Castings flaws have been cleaned up
Turbo trix ss valves
Bronze valve guides
Manly dual valve springs and titanium retainers
3g lifters
Mitsu 4 layer head gasket
Arp head studs
Brian crower 272 cams
Skunkworks racing cam gears (red)
Clear timing cover
Summit Sirricco aluminum radiator
12’slim fan
J M Fab sheet metal intake manifold
Drive Train
Act 2600
Act street lite flywheel
4 bolt rear end
Stainless steel clutch line
Extended clutch rod
Prothan motor mounts
Aws remover
Abs remover
3 speed scatter shield
Shifter cable bearings
Non cruise cable
Suspension
Energy suspension complere bushing kit
K sport coilovers
Front strut bar \
Rear strut bar
Whiteline 22mm front sway bar
Energy suspension rear 1’’ sway bar
Electronics
Eprom ecu
Dsm link v 2
Gm 3 bar map sensor not installed
Labtop with softwhere
Aem uego box wired into dsm link
300m coil on plug
Autometer phantom boost
Autometer phantom egt needs probe
Autometer phantom water temp
Autometer phantom oil temp
Autometer phantom oil pressure
Cyberdyne digital fuel pressure
2g 609 maf w/4’’ filter and adapter
Battery relocated to trunk w/box
Fuel
Walbrow 255hp
-8an to filter
Mallory efi fuel filter
-8an to fuel rail
Victory performance fuel rail (polished)
-6an from fuel rail to regulator
Aeromotive race efi pressure regulator
Turbo
Turbonetics ceramic ball bearing 62-1 with tuff turbo option (P Trim big shaft)
Bullseye stainless steel turbine housing
2g manifold
J M Fab manifold cover
ssautochrome 3’’ o2 housing
46mm wastegate
Megan racing 3’’ down pipe
Fijitsubo legas r 3’’ cat back
Slow boy racing 1g race fmic
Tial bov
Forced performance 4’’ intake pipe
Brakes
Willwood brake kit
Willwood street pads
Wagner thermo quiet rear pads
New crossdrilled and sloted rotors
Stainless steel front brake lines
Wheels
Konig rythems 18*7.5 black opal
Wanli 225 40 18 tires 90% tread
Audio
Jvc tuch screen cd player ($400)
Jvc indash electronic EQ
Lightning audio 4ch amp
2 way 3 ½ dash speakers
5 ¼ conponets with tweater and crossover
6 ½ 3 way rear speakers
Interior
92 galant ls grey seats
Perfect 1g leather steering wheel
94 eclipse shifter
Leather shift boot
Exterior
Carbon fiber venter hood (needs hood pins)
93 headlights
92 galant grill
jdm clearence lenses
Mantance
New knock sensor
New ball joints
New tir rod ends
Previous owner replaced carrier bearings
Greddy timing belt
New Mitsubishi timing tensioner
New idler and tensioner bearings
New water pump and all seals where replace when motor was built
New oem biss o ring
New passenger side wheel bearing
New clutch master cylinder
New clutch slave cylinder
New oem clutch tob
