FS: 1g part out...lots off goodies..
Number4
Lowell MA
Putting a few parts for sale for a friend...All this is coming off a 91 talon that was built but never raced and barely driven...Everything has less that 1k miles and do to personal problems he is forced to part the car out ....b/o on most of the parts if he doesn't have to ship them!! Lots of GOODIES...
Engine Parts=
Fp2 cams-$350
PTE 880 injectors-$250
6 bolt front case balance shaft-$180
Harmonic balancer-$60
Stock alternator-$40
Front facing oil filter housing-$80
L-19 Head studs-$200
Cometic head gasket-$80
Standard wiseco pistons .20 over-$250
Eagle Rods-$200
Hawer powder coated black intake manifold-$400
.20 over 6 bolt block with arp head studs-$250
kiggly 6 bolt main girdle-$100
1g head All work done by Burchur Racing-$850
Extrude Honed and O-ringed
Stainless steel 1mm valves
Super tech springs and retainers
Black powder coated valve cover- 10 fitting welded on and baffles removed-$120
Gauges=
Electric oil gauge-$40
Boost gauge-$25
Electric Fuel pressure gauge-$40
GM IAT Sensor-$20
AEM 3.5 bar MAP sensor-$120
Turbo and Inter-cooling=
ETS Brand new 4incn fmic race core-$500
Tial Q bov will include stainless steel welded flange-$220
Stainless steel intercooler pipes with IAT sensor bung-?
New DMH electric cut out-$150
Engine Management=
91 socketed ECU- work done by ecmlink-$220
ECMlink v3 full version-$550
Air Metering=
GM 3" airflow meter-$40
3in to 2.5 couples-$25
Translator (newer version)-$100
Drivetrain=
Shep racing stage 3 transmission with 4 spider center diff receipt for work done Less than 500 miles on this-$1200
ACT 2600 pressure plate-$230
ACT aluminum flywheel-$180
Cluthnet sprung 4 puck clutch-$120
FP flywheel kit-$20
Summimoto HTRZ 245/45/16 new tires-$350
3000gt nt wheels-$250
call/text-978-866-9871....Thanks...
is that 4 spider center diff open or welded? im interested and if its what i need i may contact you if im able to pull the funds from saving.
what brand, model, face color, and size are the oil, boost, and fuel gauges?
