FS: 1992 Summit White GVR4 197/1000 NH $5500 SOLD SOLD SOLD
Status
Not open for further replies.
streetmasters
NYC
I hate to do this but I am going back to school next year and have to sell it all.
OVER $20,000 Invested!!! Save your money on building a project- everything is already done
DYNO TUNED at 315HP at 19 lbs..currently running 26 lbs- est 400 HP
1992 Summit White VR4
THIS CAR IS A BEAST- 26PSI BOOST! RUNS STRONG!
Faster than my BMW 335i- it will put many cars to shame!
Launch control, Purchased from Original Owner, Window Sticker
Comes with extra set of wagon wheels with Blizzak Snow tires- good for 1 more season.
ENGINE:
Engine Stock Bottom 153,500 miles
Head: Ported - Oversized valves (Ferrea 1mm oversized) - Valve Job - Valve seals
Crower valves springs & titanium retainers
FP2 cams
4 layer head gasket
Honed extrude intake
Adjustable cam gears
COMPUTER:
DSM Link
2G MAS
NGK AFX Air-Fuel Ratio Monitor Kit
FUEL:
Denso 720
Walbro 255 re-wired
Buscher Front Mount
3" ss turbo back exhaust - high flow cat
3" Magnaflow muffler - dual tips
95 ported ceramic coated exhaust manifold
PTE 5031 RE dual bb turbo
TRANSMISSION:
Act 2600
TRE tranny with higher 5th gear
4 bolt LSD AWS Removed
Lightened Fidanza flywheel
SUSPENSION:
Hotbits FULL Suspension!! OVER 2k!
Whiteline sway bars 22mm front 26mm back
Whiteline bushings
Megan front & rear strut bars
OTHER:
ss brake lines
Battery Relocate KIt to the trunk
Racing Kill Switch
Caps replaced
Halman boost controller
Tires are generic stock type tires with very good tread left
back bumper frame replaced with a nice rustfree one
Sunroof works and does not leak
CD player works
Tape Deck Works
REPLACED WITHIN last 13,000 miles
ball joints
Water Pump
Carrier Bearings
Timing belt (still has balance shaft)
Alternator (I know - so what.)
Hawk HPS pads
Rotors
E brake cables
Knock sensor
Radiator stock
Shifter cables & Brass Bushings
Noltec rear subframe bushings
Completely went thru rear subframe - cleaned - painted
The Bad
Front drive shaft boots ripped (Have both new drive shafts - not installed)
Missing passenger rear dogleg
Car did a 180 into a ditch backwards and the rear bumper has some damage- I have a replacement rear bumper that just needs paint.
I replaced the driver door.
Rear 1/4 was dented in the accident...
These pics are from the original owner- I will post pics of the car with the damaged rear bumper, replacement bumper and dent.
Status
