FS:1992 Galant VR4 WI $2200.00 - 500whp Partout!! Must SEE
The car is being parted some stuff is already gone link here click
For those who have shown interest I just updated to album link below with motor build pics and a couple shots of the intercooler/oil cooler setup.
Selling my 1992' vr4 710/1000 in beautiful condition, NO RUST. 114k on the body 1500 on the motor. Interior looks brand new. Exterior is near flawless.
Car is built to make 500whp, reliably..
-Eagle wiseco block balanced and blue printed
-Buscher stage 3 head, cnc ported, Ferrea 1mm over int/exh valves, Crower springs, Crower ti retaners, Magnes locks, Brian Crower 288 cams
-Kevlar timting belt
-oem front cover
-cometic gasket
-arp's top and bottom
-unorthadox water pump/alternator pullies
Custom oil filter housing -08 an lines
Earls oil cooler
remote mounted filter
FP 3065 turbo on top mount header
-10 water feed/return lines
-04 Starlite oil feed with FP filter/restrictor
-10 Starlite retune line
Tial 44 wg
Full 3" exhaust
Procharger Intercooler
Tial 50 bov
FRH intake manifold w/kevlar heat spacer
AEM EMS with gm intake temp, 3.5 bar aem map sensor, and wideband o2 feedback serial gauge in glove box.
Audi radiator mounted under rad support with dual spal fans up front
New era 950cc injectors
Race shop billet fuel rail
Fuel lab regulator
denso 260lph hi preassure
-06 braided feed/return. 3/8" Alum. Feed new from tank to firewall
-TRE trans, double syncro's steel forks, the works shifts perfect.
-Billet steel flywheel, act 2600
-4 bolt lsd rear
-oem mitsu abs delete
-braided brake lines
-hawk pads
-Kyb Agx's / stock springs
The whole front subframe was pulled, sandblasted and sprayed with truck bed liner, all poly bushings, NEW manuel sterring rack.
New ball joints
New wheel bearings
New sway bar end links
Custom covers made for the holes where the stock battery and abs unit used to be
Greddy 60mm boost and egt
Greddy profect boost controller w/remote
Greddy turbo timer
VDO oil preassure
Stewart warner oil temp
Eclipse cd player
Optima Yellow top mounted in trunk
Batt. kill switch hidden above licence plate.
Keyless entry with alarm works excelent.
Everything in the car works, all lights work.
$10,500 obo
Contact Sam @ 920 277 9042
Nothing wrong with it just bored with dsm's/galant's. Moving on.
pics here
Quoting BadVr4:
looks awesome, what kind of top mount manifold are you running? also what audi radiator?
The manifold was made by me, its a replica equal length Shearer design i looked at once. (but you did'nt hear any of that from me). The rad i heard about from another board member ("cody"), i think there from a late 80's audi 90..
Quoting G:
This been in wi it's whole life?
Orriginally I'm not sure, I bought it from a fellow in Green Bay. But he said he got it from Minnesota. From the miles and condition I do not think it has seen many if any midwest winters. There is basically no rust or corrosion anywhere on the car.
Thanks for the question.
blacksheep
Urbandale, Iowa 50323
its my old car - used ti belong to Mike Miller. I sold it to Ryan in MN. I did all the stereo, gauges and greddy stuff etc. I did sell a 4 bolt and axles with the car.
The dent on the roof and the door was there when I bought the car, BTW.
click - look under interior and steering wheel install. I installed that steering wheel as well...
EDIT - I think I won that oil cooler of a nascar team on EBay if its the same one.
G
zompton
Quoting gvr4dsmer:
Quoting G:
So you never ran a carfax?
cody
Neenah, WI
bump for a extremely nice car and a great guy. someone buy it. its a steal compared to whats in it.
Bump with updated pics..
Forgot up top to mention the car does have an Optima Yellow top in a aluminum box in the trunk with a kill switch just above the licence plate. I'll try to shoot a couple pics of that this weekend..
And a bit more open to trades + cash or cash + trades.
^If it was a TDI I most likely would but unfortunatly I'm not interested, thanks though..
