hey guys , ive got my 1992 galant vr4 up for sale 332/1000, i have owner this car for almost a year and i have invested lots of time and money into this car
new parts-
timing belt replaced (didnt break just felt it needed to be replaced)
-new timing belt tension from mitsubishi
-new pulleys for timing belt
-new water pump (did just becuase i had the timing belt off)
-new balance shaft belt and tensioner
-new computer from advanced auto with 1 year warranty bought about 5 months ago
-new coolant temp sensor
-new 2.5 in stainless steel down pipe
-new full stainless steel exhaust from down pipe back just installed
-new fluids in transmission ,transfer case, and rear diff. all royal purple
ok that is all the stuff that i replaced , all these parts have about 5 miles on them
Here is a list of other mods done to the car before i bought it
-full 5 bolt conversion
-lsd rear
-aws delete
-full steel braided brake line clutch line and turbo oil line
-fully adjustable eibach suspension (coplete strut ass, with adjusters on rear shocks)
-i was tol it has a stage 2 clutch in it i didnt pull the tranny off to confirm this but the pedal is very firm and grabs excelent
-all motor mounts are red poly urathane
-trunk battery relocation
i have a clean title in hand for this car it does not look like it was in any accidents and has no rust, the mileage is wright around 150,000 and i believe it has a different motor than stock,,, that or someone just changed the valve cover because its not red like everyone elses its silver,
the car needs some minor work , like i said i put alot of time into it and just dont have any more time or money,, some things that arent perfect, the evgine has a rough idle but does idle , i was told that the screw on the throttle body has to be adjusted,,, ive never driven the car more than 5 miles since ive owned it so the rotors are kinda rusty front speakers are missing, check engine light and aws light is on, the front bumper has about a 3 inch crack on bottom drivers leather seat has normal wear, paint is faded from its age, the 1 tire in the left rear goes flat after letting it sit for over a month, i might be missing some little stuff but if you have any questions about the car please call me at 570-309-5664, i work night so i sleep from 10am to about 6 pm,, i am located in jermyn pa my zip is 18433, my price on the car is very firm due to the fact that i have more than that into the car
new parts-
-lsd rear
-aws delete
