FS: 1991 nile back vr4 3200 philly
jarhead
Member
philly
1991 vr4
141101 on the clock.
no rust on body or dents. the hood lip where it latches has some rust on the under side.
interior is mint, no rips or tears.
sunroof works and does not leak.
less then 15k on block and trans
Engine:
Rebuild Short Block
Crower Camshafts Stage 2 272/272
Crower Valve Spring & TI Retainers
Extensive intake and exhaust port work
Balance shaft eliminator kit
Old school intake manifold
Turbo:
Evo3 16g
Trans:
T.R.E STAGE 4 TRANSMISSION
ACT Flywheel
ACT Heavy Duty Sprung 6-Puck Clutch Kit
Suspension:
Eibach Pro Kit
KYB AGX Adjustable shocks Rear Pair
KYB GR-2 / Excel-G shocks Front Pair
Goodridge Stainless Steel Brake Lines
Other Aftermarket parts:
Koyo Aluminum Race Radiator
Extreme Turbo Systems 7" Street Intercooler Kit
TiAL 50mm Q Blowoff Valve
Full 3in' exhaust systems
Afpr rewired walbro 255
2gmaf fresh plugs. Just checked timing
