FS: 1991 GVR4 (#627/2000) - Illinois - $5000obo
Status
Not open for further replies.
SAfrican
Illinois
I have my car list at the following eBay Link.
Vehicle Description:
My wife and I bought this car back in 1998, and since then it’s been an absolute joy to own and drive. For over five years this has been our primary source of transport. It has served as both a daily driver/family car, and then as a weekend warrior whenever the need arose. And all this with zero issues. In 2004 my wife successfully bracket raced the car all year, running consistent 12.4’s, and then made the 2004 DSM shootout in Norwalk, OH (she came second in the SA class).
Last month I hurt the built engine that was in the car, a plug wire had a tear in it causing me to burn one of the pistons. I then made the decision to replace the broken engine with a good spare one that I had laying on the garage floor and sell it. Despite loving the car to death, I needed to upgrade it to a good reliable SUV – I have a six year old that requires the comfort and reliability of something newer and bigger. The timing seemed right for this upgrade.
Car: 1991 Galant VR4
# 627/2000 – Black/Sunroof – Chicago based
VIN: JA30X56U9MZ011028 (Clean Title)
Mileage: +220K on the body, few scratches and one or two tiny dings on the car (barely noticeable). Interior is in very good condition, leather seats are perfect – zero tears. No idea what the mileage is on the replacement stock motor, except that it does not smoke or drip oil anywhere. Appears to have decent compression (you will need to check that yourself). Timing belt is in very good condition (replaced with the one that was on my built motor).
ENGINE:
- 2.0l 4g63 (Stock motor with decent compression).
- PTE SC61 – less than 2000 miles on it (bought from AURA racing)
- K&N filter
- Al Blaha mas – car has not fuel cut in over 7 years
- DNP tubular equi length header
- tial 44mm Wastegate
- Custom made DP with external dump
- 3” SS turbo back exhaust, with test pipe (drop in catalytic provided for emissions tests)
- Evo8 intercooler with 2.25” intercooler piping
- 1g crushed BOV
DRIVETRAIN:
- Stock Transmission – first gear grinds is rush into gear – otherwise it shifts extremely well
- 2600 ACT clutch – about 1000miles on it
- Stock rear end – never had a problem with the 3-bolt – numerous 1.6 – 1.7 60 foot times on it to show it’s strength
FUEL MANAGEMENT:
- Walbro 255 rewired
- RC 660 cc Injectors
- -6 Braided fuel line with modified stock fuel rail (90-degree line adapter welded onto in-tank assembly)
- modified fuel rail to accept –6 fuel line
- SAFC II
- Manual boost controller
- Bung on exhaust for wideband
- turbo timer (not sure what make)
SUSPENSION/BRAKES:
- Whiteline lowering springs (purchased mid last year)
- New KYB shocks (less than a year old)
- Slotted and drilled rotors (3 – I had to replace the rear passenger side with a stock rotor which got damaged by a seized rotor – still have the damaged rotor if needed)
- 4WS Removed
OTHER:
- New stock radiator (change last November)
- Stock wheels with new tyres (not sure what make)
- Sony CD player with detachable face – MP3 plug in available
CURRENT ISSUES:
1) Aircon does not work – could be a fuse issue, just never had the time to try and fix it
2) Rear passenger tail light is cracked for the last 4 year. I’ve had replacement tail light, but never got around to changing it cause the crack on the current one wasted all that noticable.
3) Rear passenger door has a little rust on it (no visible as it’s on the inside), but I have bought a clean replacement door (exact color) but never got around to installing it.
The body is straight, but it has a few door scratches (no dings) from being parked in paring lots. The rear bumper has some noticeable scratches on it, and the wing has a few two (I have a spare wing which will go with the car). The underside has surface rust like any other older mid-west car. The rear passenger door has a little understand in non-visible place, and for that I purchased a second hand clean door (black - not installed).
steve
NJ
The price is in the title, per the forum rules.
SAfrican
Illinois
And at that price I will throw in a great set of 17 inch Enkei wheels and Yoko Parada's with +80% life on them. Seen here:
Pic1
Pic2
I just hate to see her stand in my driveway, I just want her to go to a good family.
yupp i bought the car and yes its staying in illinois...thanxz vernon...the car is runing good!!and will be running better /ubbthreads/images//graemlins/grin.gif im on board now guys #627/2000
Status
