GreenGSX
1991 Galant VR4 #255 of 2000
200K miles
Rebuilt stock engine with new bearings, rings, ARP head studs, and polished crank. 5K miles
Ground control coil-overs on AGX adjustables
EVO FMIC w/ 2.5" SS pipes
16G turbo
Griffen radiator w/spal fan
Working Cyclone intake
2G MAF
RC 550's
SAFC
BM FPR (43 base PSI)
EVO fuel pump
17" aluminum wheels
Winter steelies w/ Hakka's
rear PS capped off.
new front brakes.
SS brake lines
Carbon Fiber hood
2.5" turbo back Exhaust with dummy cat.
ported O2 housing
2G exhaust manifold.
good shifting transmission
ACT 2100 less then 5K on disk
The pictures in the add are of the car about this time last year. It does not look as clean as it has gone through last winter and then sat all summer. Some of the parts were moved between the One Lap VR4 and this car and then returned when the event was over. It is complete and everything is there and working. One of the dog leg trim pieces fell off last winter but I have that just never put it back on. This car has some rust issues and I do not want to drive it anymore. It had leaked water around the windshield allowing water to travel down the inside of the a-pillar and into the front passenger corner of the car. I suspect its pretty crusty.
But it has all the parts and if you are inclined to put the work into it go for it. I spent a couple of hours chasing down its issues and only found a sketchy SAFC install that I fixed. I expected that to resolve its running issue but it didn't and I don't have the time for it anymore. If that would have fixed it I would have driven it this winter and then sent it to the crusher after a part-out in the spring.
I am in the middle of a DSM purging in an effort to get my garage back and get some cash for the 2010 One Lap. I currently have 3 cars, the One Lap VR4, the shell of my track GSX, and this VR4. Too many cars not enough room in the garage.
The car is being sold "as is"
$2000 OBO
200K miles
16G turbo
2G MAF
RC 550's
SAFC
EVO fuel pump
17" aluminum wheels
rear PS capped off.
new front brakes.
SS brake lines
Carbon Fiber hood
ported O2 housing
$2000 OBO
