FS: 1991 galant vr-4 1755/2k $2500 poughkeepsie sold!!!!!!!!
coreyc123
Active member
pougkeepsie ny
i dont want to sell it but i need money for school.the bad is it needs the new clutch to be installed and it has a boost leak.also the Alternator just went and need a battery will have to be towed but runs after alternator is done
1755ok2000
160k on the body and 45 on the motor and trans
what i was told when i bought it it had the head gasket,water pump,timeing belt replaced.
also i was told it has new vale seal and 3rd gen lifters with a port and polished head with over sized valves but i have no documentation for the motor but i have documentation for the trans being rebuilt from turbo trixs.the aws is still working and the car runs good for the most part it needs a little tlc.
mods
-auto meter boost gauge air fuel oil pressure volts and water temp
-safc2
-font mount with hot side hard piping
-evo 3 16g
-evo 3 exhaust manifold
-full 3"exhaust and down pipe
-magnaflow stainless steel muffler
-gm 3" maf and trans
-act light flywheel
-act 2100 slip but will include a new but not installed act Clutch Kit # MB1-HDG6 MB1-HDG6 wit a torque capacity of 412ft/lbs
-unorthafox crank pulley
-custom front door panel to fit 6.5 speakers
-brembo rotor front and rear with 2g front brake upgrade
-stainless steel breaklines
-stainless steel oil feed and return line not installed yet
-kyb gr2 front and rear
-front and rear strut bars
-new alternator and belt with optiman red top battery relocated to the trunk
-rewired 255 fuel pump
-evo1-3 mud flaps and the jdm rear window and door decals
coreyc123
Active member
pougkeepsie ny
no sunroof a little rust on driver door and a very small spot on the trim above the bumper ill getter better pics it rained up here all weekend
Good luck on the sell, I would buy if I had the money. Still trying to sell my car.
