FS: 1990 Eagle Talon TSI AWD Roller $1000 SOLD SOLD
streetmasters
NYC
This Car was sold
Has FULL energy suspension polyurethane bushing kit ALL AROUND!!!
Eagle Talon TSI AWD 73k ORIGINAL MILES
ORIGINAL WINDOW STICKER
Its hard to see but on the passenger side of the hood there is clear coat peeling-
some dings in the fender also hard to see from the pics
This needs:Motor, Tranny, Ecu, Power Steering rack (probably easy find from a junk yard)
There are specs on the front bumper and fenders that are hard to see-need a tow or a winch if you only have a trailer
Tires are like new- Needs a steering wheel and shift knob (like 30 dollars online)
Title is Clean
Put these things together and you have a pretty nice car
TALON UPGRADES(Provided by the original owner-thank you)
1. HKS Stainless Steel Hiper Exhaust system with 120mm diameter exhaust tip. The HKS Hiper system is constructed using an unchambered (304) stainless steel muffler assembly, high-quality computerized welds, and large diameter ceramic-coated steel piping. (only 1,000 miles on exhaust system!)
2. Alamo Autosports Side-Mount Intercooler
(designed and manufactured by Corky Bell of Bell Engineering (www.bellengineering.net) for Alamo Autosports)
3.ARC Rear lightweight Tubular Anti-roll bars (Japan item only),(less than half the weight of the Suspension Techniques anti-roll bars)
4.Archer Brothers Big Brake Upgrade (bigger front rotors and calipers)
5.Archer Brothers rear molybdenum Upper Strut Tower Brace
6.Energy Suspension polyurethane bushings install throughout entire vehicle,(same brands of suspension bushings, brakes, used by Archer Bros. in winning 6 World Class Championships with the Eagle Talon!)
7.Porterfield R-4 Carbon-Kevlar racing brake pads
(Ultra fast stopping! The R-4 pads have 0.5 coefficient of friction when COLD!)
8.Andial Intercooler Temperature gauge,(displays intercooler INLET temperature, intercooler OUTLET temperature, and their temperature difference in degrees Fahrenheit)
9. GAB 8-way adjustable rear shocks
10.GAB 4-way adjustable front shocks
11.Eibach front and rear springs
12.Braided stainless steel brake lines
13.DSS (Diamond Star Specialties) in-tank Hi-Flow fuel pump
14.Hidden Fuel Cut-off switch (No fuel, engine can't start!)
15.Set of 4 original OEM wheels with Bridgestone Blizzak snow tires
16.Alpine speakers in doors and rear shelf (bolt-on replacement installation: NO CUTTING done!)
17.Alpine Silk-Dome tweeters in dash (bolt-on replacement installation: NO CUTTING done!)
18.Redline replaced in rear differential at 500 miles and at every 15,000 miles thereafter
no motor tranny or ecu
