FS: 1720 part out colorado
broncfan56
Divide, CO
As the title states I am parting out 1720. The parts are located in Colorado Springs, the shell is now gone, for the most part what is below is what I have.
All prices are for parts, you pay shipping costs and Paypal fees. My Paypal address is [email protected]
2g intake manifold with throttle body, elbow, and coil pack. will separate. $100
13g turbo as pictured. In and out shaft play, no side to side play. $50
front bumper, has been cut and not in perfect condition, paint is horrible. $50
Rear bumper. $75
Carpet, needs cleaned one small rip. $50
Center console $80
Dash guage cluster and trim, reading 28x,xxx miles $100
under steering wheel trim $20
passenger side front and rear Doglegs $50
Door panels, exterior $25 a piece. DS rear sold
Front seats, driver seat has a very worn spot on bolster. $100
Rear seat $100
Driver and passenger side trim pieces $5-10 a piece let me know what you need and we will figure it out. DS a pillar sold
Driver side visor $10
Stock appearing exhaust $20
Exhaust manifold (I believe 2g?) made in china $20
Front and rear door cards $50 a pair
front seat belts $20 a side $30 for both
Rear seat belts $20
gas door $10
Glove Box $20
Grill with 1 broken tab as pictured $50
GVR4 radiator w/o fans $20 also have an eclipse radiator with 2 stock fans $30
headlights $50
corner turn signals $20.
Headliner with trim pieces $50
non eprom ecu $50
behind the rear seat dash trim $10 and speaker covers $10 a piece.
Rear view mirror $10
side mirrors, one green, one black $20 a piece
sunroof assembly $100. sunroof control box/interior lights $20
t3/t4 tubular manifold with external wastegate flange. has a cracked weld, not the prettiest part. $50
trunk trim pieces, not in great shape but they would work if you didn't have any $50. 4lug spare $20.
theevozero
Odessa, Texas
First of all, that is not a 14b. That sir is a 13g. They reside from auto dsm. It also apears to have a tdo5h turbine housing on it, or just a 7cm turbine gasket.
Second, dips on the drivers A pillar(as long as the mounting tabs are intact) and the trunk side panels.
broncfan56
Divide, CO
Thanks for the knowledge, I'll update that in a few minutes. Also the mounting tabs are fine they just need new detail clips/pins that slide in.
Trunk interior is spoken for you are next in line if it doesn't work out.
broncfan56
Divide, CO
There is a shifter in the car. I don't know if it is the stock one but I will post a picture tomorrow after I get off.
trexn8
Aurora, CO
I am interested in gauge cluster trim if available, I can pick it up /ubbthreads/images/graemlins/smile.gif
5OF2k
colorado springs, colorado
i might be interested in the doglegs and outer door panels.... Mine have a bit of chipping and flaking on them. any better/closer pics of these? I suppose I could come and check them out in person too.
Shoot me a PM man, we can go from there!
-Jake
Epifool
greencastle, In
Hey 5ofi 2k, i need a drivers side rear dogleg. I'll buy your chipped flaky one if you get the ones your after. Lost mine three days ago, and i feel like i lost a knee or somethin.
Galantvr4559
Denver, CO
To remove rear bumper there are two bolts going down on the trunk floor. Take those 4 bolts out and it will slide off
Clifton, Colorado
Hi !
Sad to hear you will be parting this car out, but I may be able to take some parts off you...
I need :
Driver side A-pillar ( I saw someone took dibs on it but if it fell through I will most definitely take it)
Spark plug cover
A/C belt tensioner
Please let me know which of these parts you still have and I would be glad to purchase them from you.
Cheers! Colby
#1708
Located in Western Colorado
maroonmetallic
central WI
Did you have the wiring that is a 6-position connector by the MAF to the fan?
I don't need the resistor but Id like the wiring that connects to it.
Price?
Thanks,
-Shawn
